December 15, 2011, 03:57 |
#21 |
Claus Meister
Rep Power: 18 |
For the 2nd question:
template <class Cmpt> inline SymmTensor<Cmpt> twoSymm(const Tensor<Cmpt>& t) { return SymmTensor<Cmpt> ( 2*t.xx(), (t.xy() + t.yx()), (t.xz() + t.zx()), 2*t.yy(), (t.yz() + t.zy()), 2*t.zz() ); } Take a look into Tensorl.H in OpenFOAM/OpenFOAM-1.7.x/src/OpenFOAM/lnInclude/. |
December 15, 2011, 04:04 |
#22 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Good morning Rui,
With respect to the first question, then fvc::grad(U) will return a tmp<volTensorField>, however, the transpose ( .T() ) is only defined on volTensorField and not tmp<volTensorField>, thus in order to remove the tmp-status, you write fvc::grad(U)(). Now you have a volTensorField, and you can perform the operations you would like to do with it. I hope that it clarified things, Niels |
December 15, 2011, 11:02 |
#23 |
Rui Vizinho de Oliveira
Rep Power: 15 |
Thank you so much too both of you
Best regards Rui |
February 14, 2012, 16:08 |
#24 |
Matthew J. Churchfield
Rep Power: 19 |
Matvej,
Thanks for your description of ddtPhiCorr. I went into the code myself and saw the same formulation you see. Do you know what the purpose of ddtPhiCorr is? No one explains its purpose. A few people think it is the Rhie-Chow interpolation, but it is not. It is some sort of time correction, but also compares the old Rhie-chow interpolated flux to the linearly interpolated flux. I have removed the ddtPhiCorr from my code and found the code runs similarly, but takes more iterations of the pressure solve to converge. Thank you, Matt |
February 21, 2012, 22:23 |
#25 |
Santiago Marquez Damian
Rep Power: 24 |
http://www.cfd-online.com/Forums/ope...ipulation.html
http://www.cfd-online.com/Forums/ope...rua-u-phi.html http://www.cfd-online.com/Forums/ope...predictor.html Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D. Research Scientist Research Center for Computational Methods (CIMEC) - CONICET/UNL Tel: 54-342-4511594 Int. 7032 Colectora Ruta Nac. 168 / Paraje El Pozo (3000) Santa Fe - Argentina. http://www.cimec.org.ar |
April 7, 2013, 19:37 |
#26 |
Jialin Su
Rep Power: 13 |
Hi Foamer,
I find this thread fairly informative. But I would like to seek clarification for some of my understanding for the following code of piso/simple/ico foam: //set up the linear algebra for the momentum equation. The flux of U, phi, is treated explicity //using the last known value of U. fvVectorMatrix UEqn ( fvm::ddt(U) + fvm::div(phi, U) - fvm::laplacian(nu, U) ); // solve using the last known value of p on the RHS. This gives us a velocity field that is // not divergence free, but approximately satisfies momentum. See Eqn. 7.31 of Ferziger & Peric solve(UEqn == -fvc::grad(p)); // --- PISO loop---- take nCorr corrector steps for (int corr=0; corr<nCorr; corr++) { // from the last solution of velocity, extract the diag. term from the matrix and store the reciprocal // note that the matrix coefficients are functions of U due to the non-linearity of convection. volScalarField rUA = 1.0/UEqn.A(); // take a Jacobi pass and update U. See Hrv Jasak's thesis eqn. 3.137 and Henrik Rusche's thesis, eqn. 2.43 // UEqn.H is the right-hand side of the UEqn minus the product of (the off-diagonal terms and U). // Note that since the pressure gradient is not included in the UEqn. above, this gives us U without // the pressure gradient. Also note that UEqn.H() is a function of U. U = rUA*UEqn.H(); I would like to know if rUA and UEqn.H() use the values of U from the previous iteration or the values of U obtained after the momentum predictor? i.e. are UEqn.A() and UEqn.H() automatically updated after "solve(UEqn == -fvc::grad(p))" is done? I read a post from Santiago saying that they will be updated. But I would like to confirm again. Thank you. Regards, Callum |
April 8, 2013, 02:21 |
#27 |
Before you have not assigned a new values for velocity with:
1) U = ... or 2) UEqn.solve(....) you have old iteration values. One can store them explicitly as well with U.storePrevIter() and then call again later with U.prevIter().
Best regards, Dr. Alexander VAKHRUSHEV Christian Doppler Laboratory for "Metallurgical Applications of Magnetohydrodynamics" Simulation and Modelling of Metallurgical Processes Department of Metallurgy University of Leoben http://smmp.unileoben.ac.at Last edited by makaveli_lcf; April 8, 2013 at 02:23. Reason: Additions |
April 8, 2013, 07:37 |
#28 |
Jialin Su
Rep Power: 13 |
Hi Alex,
Thank you for the reply. I am new to OF (and C++) and the question below might be a bit dumb. But could you or anyone tell me the difference between "solve(...." alone and "UEqn.solve(..."? Are they indeed the same? (I'd thought so until I saw the line "pEqn.solve(..." in the code)...Thanks. Regards, Jialin Su |
April 8, 2013, 07:44 |
#29 |
The difference is following:
1) UEqn ( ddt(U) + div(phi, U) == laplacian(nu, U) - grad(p) ); here you already include pressure in you matrix UEqn. And you can solve momentum equation with UEqn.solve(). 2) But suppose you would like to keep pressure influence away from UEqn matrix (like it is done in PISO algorithm): UEqn ( ddt(U) + div(phi, U) == laplacian(nu, U) ); and to solve proper momentum equation (where the pressure gradient should exist) you have to call solve(UEqn == - grad(p)) thereby you include pressure in momentum equation solution, but keep it away from your linear system UEqn.
Best regards, Dr. Alexander VAKHRUSHEV Christian Doppler Laboratory for "Metallurgical Applications of Magnetohydrodynamics" Simulation and Modelling of Metallurgical Processes Department of Metallurgy University of Leoben http://smmp.unileoben.ac.at Last edited by makaveli_lcf; April 8, 2013 at 07:45. Reason: Mods |
April 8, 2013, 10:45 |
#30 |
Jialin Su
Rep Power: 13 |
Danke sehr, Alex. Jetz verstehe ich.
Freundliche Gruesse Jialin Su |
April 13, 2013, 11:05 |
#31 | |
Avdeev Evgeniy
Rep Power: 21 |
I have one more question around terms .A(), .H(), .T(). As said before Quote:
I found them in article http://openfoamwiki.net/index.php/Co...lockedCellFoam Code:
... scalarField& lower_ = UEqn.lower(); scalarField& upper_ = UEqn.upper(); scalarField& diag_ = UEqn.diag(); ... Thanks. |
April 13, 2013, 14:44 |
#32 |
Rep Power: 24 |
Hi, A()=diag()/mesh.V()
See fvMatrix.C Code:
00721 template<class Type> 00722 Foam::tmp<Foam::volScalarField> Foam::fvMatrix<Type>::A() const 00723 { 00724 tmp<volScalarField> tAphi 00725 ( 00726 new volScalarField 00727 ( 00728 IOobject 00729 ( 00730 "A("+psi_.name()+')', 00731 psi_.instance(), 00732 psi_.mesh(), 00733 IOobject::NO_READ, 00734 IOobject::NO_WRITE 00735 ), 00736 psi_.mesh(), 00737 dimensions_/psi_.dimensions()/dimVol, 00738 zeroGradientFvPatchScalarField::typeName 00739 ) 00740 ); 00741 00742 tAphi().internalField() = D()/psi_.mesh().V(); 00743 tAphi().correctBoundaryConditions(); 00744 00745 return tAphi; 00746 }
May 28, 2013, 05:32 |
#33 |
Emad Tandis
Rep Power: 16 |
Hello
How does OpenFOAM work when This function is called: UEqn.A() I mean if phi or U was changed, UEqn.A() changes? or this function depend on mesh and transportProperty? |
July 4, 2013, 06:42 |
#34 | |
Dongyue Li
Rep Power: 18 |
Thanks |
July 4, 2013, 06:45 |
#35 | |
Dongyue Li
Rep Power: 18 |
If I was wrong correct me. |
July 9, 2013, 10:21 |
#36 |
Avdeev Evgeniy
Rep Power: 21 |
Santiago, propably nooby question, anyway
from fvMatrix.C Code:
00742 tAphi().internalField() = D()/psi_.mesh().V(); A()=diag()/mesh.V() or another string? And I tryed on practice and got something more like A()~diag()/mesh.V(), i.e. approximately. Is it right? Thank you. |
OpenFoam programming | prapanj | OpenFOAM | 10 | March 18, 2010 08:23 |
Programming in OpenFOAM | vinu | OpenFOAM | 2 | July 11, 2009 11:16 |
two questions about udf programming | Vincent | FLUENT | 1 | October 5, 2008 01:24 |
new CFD Programming Forum | Thinker | Main CFD Forum | 14 | November 19, 2002 17:03 |
Programming in C | Tony | Main CFD Forum | 5 | March 7, 2002 13:40 |
