May 11, 2012, 09:49 |
#81 |
Andrea Ferrari
Rep Power: 17 |
Have a look at the pictures i attached. maybe it might be a boundary effect in case of liquid droplet (first two pictures). i would try to make a bigger surrounding domain to see if performs better.
andrea |
May 11, 2012, 12:21 |
#82 |
Jens Klostermann
Rep Power: 17 |
Keep in mind that the parasitic currents are more pronounced in the fluid with the lower dynamic viscosity (gas phase). Thus damping the parasitic currents less
Jens |
May 11, 2012, 12:24 |
#83 | |
Robert Castilla
Rep Power: 17 |
Robert |
May 11, 2012, 12:43 |
#84 |
Andrea Ferrari
Rep Power: 17 |
hi jens,
thanks to join the discussion. this might explain picture 2 in which is clearly visible that spurious currents are higher in the gas phase but shouldn't we get something similar, but reversed, in the other case? best andrea |
May 11, 2012, 13:14 |
#85 |
Jens Klostermann
Rep Power: 17 |
Hi Andrea,
It is fun reading your thread and seeing how you progress! In the case 2 (bubble case) the parasitic current are only visible in the bubble (gas drop) and can "cancel out" each other since they are compact in a bubble. In the case 1 (drop case) it is harder for the parsitic currents to "cancel each other" since there are seperated by the liquid drop. Jens |
May 13, 2012, 17:19 |
#86 |
Anton Kidess
Rep Power: 30 |
Andrea, you were right about the domain size - use a larger domain, and the convergence problems go away The smearing along the mesh direction is somewhat weird, but doesn't seem to be reflected in the force field.
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
May 13, 2012, 21:40 |
#87 |
Pei-Ying Hsieh
Rep Power: 18 |
Hi, Anton,
I retrieved the latest interfoamssf code. Made a couple of changes needed for OpenFOAM-2.1.x so that interFoamSSF compiled successfully. However, when I ran the staticDroplet test case, the case diverged. I am wondering if I need to make changes for it to run? Thanks! Pei-Ying ---------------------------/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.x-f1044c880abb Exec : interFoamSSF Date : May 13 2012 Time : 20:36:25 Host : "jali" PID : 6613 Case : /home/hsieh/OpenFOAM/hsieh-2.1.x/solvers/interfoamssf/testCases/staticDroplet nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 PIMPLE: no residual control data found. Calculations will employ 4 corrector loops Reading field p Reading field alpha1 Reading field U Reading/calculating face flux field phi Reading transportProperties Selecting incompressible transport model Newtonian Selecting incompressible transport model Newtonian Reading g Calculating field g.h time step continuity errors : sum local = 0, global = 0, cumulative = 0 DICPCG: Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 0, global = 0, cumulative = 0 Courant Number mean: 0 max: 0 Starting time loop Courant Number mean: 0 max: 0 Interface Courant Number mean: 0 max: 0 Time = 5e-07 PIMPLE: iteration 1 Subcycle 1 DILUPBiCG: Solving for alpha1, Initial residual = 0, Final residual = 0, No Iterations 0 Liquid phase volume fraction = 0.936 Min(alpha1) = 0 Max(alpha1) = 1 PIMPLE: iteration 2 Subcycle 2 DILUPBiCG: Solving for alpha1, Initial residual = 0, Final residual = 0, No Iterations 0 Liquid phase volume fraction = 0.936 Min(alpha1) = 0 Max(alpha1) = 1 GAMG: Solving for pc, Initial residual = 1, Final residual = 6.73003e-08, No Iterations 9 DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 8.94836e-10, No Iterations 6 DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 8.94835e-10, No Iterations 6 DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 8.94833e-10, No Iterations 6 GAMG: Solving for p, Initial residual = 1, Final residual = 7.10299e-08, No Iterations 13 time step continuity errors : sum local = 1.23283e-08, global = 2.02179e-20, cumulative = 2.02179e-20 GAMG: Solving for p, Initial residual = 0.103026, Final residual = 7.62369e-08, No Iterations 11 time step continuity errors : sum local = 2.34517e-08, global = 1.13891e-20, cumulative = 3.1607e-20 GAMG: Solving for p, Initial residual = 0.00322057, Final residual = 3.33724e-08, No Iterations 8 time step continuity errors : sum local = 8.882e-09, global = -3.97863e-21, cumulative = 2.76284e-20 PIMPLE: iteration 3 Subcycle 2 DILUPBiCG: Solving for alpha1, Initial residual = 0.00219012, Final residual = 9.7882e-16, No Iterations 3 Liquid phase volume fraction = 0.936 Min(alpha1) = 3.35461e-26 Max(alpha1) = 1 #0 Foam::error:rintStack(Foam::Ostream&) in "/home/hsieh/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64Gcc46DPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/home/hsieh/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64Gcc46DPOpt/lib/libOpenFOAM.so" #2 in "/lib64/libc.so.6" #3 Foam::sqrt(Foam::Field<double>&, Foam::UList<double> const&) in "/home/hsieh/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64Gcc46DPOpt/lib/libOpenFOAM.so" #4 at interfaceProperties.C:0 #5 in "/home/hsieh/OpenFOAM/hsieh-2.1.x/platforms/linux64Gcc46DPOpt/bin/interFoamSSF" #6 in "/home/hsieh/OpenFOAM/hsieh-2.1.x/platforms/linux64Gcc46DPOpt/bin/interFoamSSF" #7 __libc_start_main in "/lib64/libc.so.6" #8 at /home/abuild/rpmbuild/BUILD/glibc-2.14.1/csu/../sysdeps/x86_64/elf/start.S:116 Floating point exception |
May 14, 2012, 04:14 |
#88 |
Andrea Ferrari
Rep Power: 17 |
Hi Anton,
did you just double the domain (200e-6x200e-6x200e-6 and 40x40x40 cells) to get those results? because i got again bad results from my tests. Did you change anything else? andrea |
May 14, 2012, 05:41 |
#89 |
Anton Kidess
Rep Power: 30 |
Andrea, here is the setup I used. Did you remember to change setFieldsDict?
May 14, 2012, 06:06 |
#90 |
Anton Kidess
Rep Power: 30 |
Pei-Ying, the repository version still uses alpha1_ to calculate 'w' in interfaceProperties.C. If unboundedness is larger than 1e-6, then that can lead to problems. If you change line 131 to use alpha1c_, all should be well.
Alternatively, initialize the simulation with a smaller time-step (e.g. 1e-7), and then when convergence sets in you can restart with a larger time step. - Anton
May 14, 2012, 09:45 |
#91 |
Andrea Ferrari
Rep Power: 17 |
After some attempts I realized why I had different results. The issue seems to lie in the smoothing of the gradient, so i decided to comment it out for the moment. I think more tests in this direction are needed before push it in the repository.
Without the smoothing of gradAlpha i got really nice results (see attached picture). andrea |
May 14, 2012, 10:00 |
#92 |
Anton Kidess
Rep Power: 30 |
Indeed already after seeing your first results with smoothing I've been thinking about the smoothing and the inclusion of an on/off switch. It would be interesting to see how the performance is on dynamic problems.
May 21, 2012, 11:40 |
#93 |
Anton Kidess
Rep Power: 30 |
I started thinking about the moving droplet test case. Does any one have suggestions how to best build the mesh in fig 6a (see attachment)?
May 21, 2012, 11:47 |
#94 |
Rep Power: 16 |
I think snappy produces this mesh easily. If you provide and stl-file with the outer cylinder, the first step of snappy would be to delete the cells cutting the boundary and produce that mesh - or am I wrong?
May 21, 2012, 11:56 |
#95 |
Andrea Ferrari
Rep Power: 17 |
i think you are right, just use snappy without "snap" option. It should do the job.
andrea |
May 22, 2012, 11:20 |
#96 |
Andrea Ferrari
Rep Power: 17 |
This is what i have obtained with snappyHexMesh. The mesh seems the same as in the paper. Did you already think about how to implement filter of capillary forces and capillary fluxes (pag 8-9)?
best andrea |
May 22, 2012, 11:46 |
#97 |
Anton Kidess
Rep Power: 30 |
Looks better than what I got with Gambit Which software did you use to generate the STL file? And can you upload your snappyHexDict?
I thought I'd try the test case without filtering, see what comes out and then add it. - Anton
May 22, 2012, 11:58 |
#98 |
Andrea Ferrari
Rep Power: 17 |
i used gmsh, http://www.geuz.org/gmsh/,it is a really easy software if you need simple geometry. The case is too big to be uploaded here. If you give me your e-mail i can send you (constant and system dir + stl).
best andrea |
May 22, 2012, 12:17 |
#99 |
Anton Kidess
Rep Power: 30 |
I actually already had an STL file generated with Salome (also trivial), I was just curious about what else can be used. Together with your dict file I also have a mesh now I did however turn off the snap feature - I think it's unnecessary here.
- Anton
May 23, 2012, 05:49 |
#100 |
Andrea Ferrari
Rep Power: 17 |
What boundary conditions did you choose? They write fixed velocity and zeroGradient for pressure everywhere, but on the jagged cylinder the correct condition should be wall BC, or not?
andrea |
capillary flows, interfoam, parasitic currents |
how to monitor free surface elevation vs time in OF? | ozgur | OpenFOAM Post-Processing | 56 | September 14, 2015 09:11 |
parasitic currents | Pei-Ying Hsieh | Main CFD Forum | 0 | January 13, 2009 20:58 |
Parasitic currents reduction | hsieh | OpenFOAM Running, Solving & CFD | 0 | January 13, 2009 16:44 |
Parasitic currents reduction | hsieh | OpenFOAM Running, Solving & CFD | 0 | January 13, 2009 16:37 |
Modelling ocean currents of the past Earth | pgm | Main CFD Forum | 3 | March 2, 2005 09:45 |
