Interpolation using interpolationLookUpTable or interpolationTable classes |
October 2, 2009, 17:56 |
Scott Haynes
Rep Power: 17 |
I’d like to perform an interpolation on a volScalarField using a lookup table of values, interpolating linearly between defined points. For example if I have points (x & y, as shown in the table below and volScalarField X, I want to make a volScalarField Y corresponding to column y.
x | y ------ 0 | 0 1 | 2 X=[0.2 0.4 0.5 0.6] i.e. Y would equal Y=[0.4 0.8 1.0 1.2 Based on the table . My first question is what class would be the best for this type of interpolation (Note that in the end it will not be a linear as shown above). After reading through the doxygen guide it looks like there are two classes to start with, "interpolationLookUpTable" and "interpolationTable". I'm not sure of the distinction between the two. I found a previous post regarding interpolationTable so I started there and I wrote a short program to figure out how to use it . Code:
#include "fvCFD.H" #include "interpolationTable.H" #include "List.H" int main(int argc, char *argv[]) { #include "setRootCase.H" #include "createTime.H" #include "createMesh.H" volScalarField X ( IOobject ( "X", runTime.timeName(), mesh, IOobject::MUST_READ, IOobject::AUTO_WRITE ), mesh ); // x|y //------ Tuple2<scalar,scalar> a(0,0); Tuple2<scalar,scalar> b(1,2); List< Tuple2<scalar,scalar> > c ( a, b ); scalar d=0.5; Foam::interpolationTable<List<Tuple2<scalar,scalar> > > JUNK(c, {0,1,0,0}, ""); volScalarField Y=JUNK(X); Info << Y << endl; return 0; } crap3.C: In function âint main(int, char**)â: crap3.C:40: error: expected primary-expression before â{â token crap3.C:41: error: no match for call to â(Foam::interpolationTable<Foam::List<Foam::Tuple2 <double, double> > >) (Foam::volScalarField&)â I think the error in line 40 has something to do with the boundsHandling argument. The constructor for this class is: Code:
interpolationTable ( const List<Tuple2<scalar, Type> >& values, const boundsHandling bounds, const fileName& fName ); Thanks |
May 19, 2011, 11:04 |
Illya Shevchuk
Rep Power: 17 |
Hello Scott,
did you find a solution for implementing lookup tabels and the difference between mentioned classes? Regards, Ilya |
May 19, 2011, 12:52 |
Scott Haynes
Rep Power: 17 |
It's been so long I can't remember specifically what I was asking but I do remember the solution. I just went ahead and wrote a function to do look ups for scalar fields, see below.
volScalarField SHlibInterp::Interp1(List<scalar> X, List<scalar> Y,volScalarField& Xi,volScalarField& Yi) { scalar m; scalar b; int FOUND; int jj; forAll(Xi.internalField(),ii) { FOUND=0; jj=0; while((FOUND==0) && (jj<X.size())) { if(Xi.internalField()[ii]<X[0]) { Yi.internalField()[ii]=0; FOUND=1; } else if(Xi.internalField()[ii]>X[X.size()]) { Yi.internalField()[ii]=Y[jj]; FOUND=1; } else if(Xi.internalField()[ii]>=X[jj] && Xi.internalField()[ii]<X[jj+1]) { m=(Y[jj+1]-Y[jj])/(X[jj+1]-X[jj]); b=Y[jj]-m*X[jj]; Yi.internalField()[ii]=m*Xi.internalField()[ii]+b; FOUND=1; }; jj=jj+1; }; }; return(Yi); }; |
May 20, 2011, 08:06 |
Illya Shevchuk
Rep Power: 17 |
Thank you!
August 31, 2012, 09:51 |
Reading Scalars from dictionaries
#5 | |
I have a similar problem. It seems that your function is suitable for interpolating between scalars. So I want to use your function. But I should read X, Y and Xi from dictionaries. Do you have any idea to do this? Sincerely yours, Hossein |
September 3, 2012, 08:23 |
It is solved. |
Single v.s. double precision | Confused | CFX | 15 | November 10, 2016 05:42 |
momentum interpolation for collocated grid | Hadian | Main CFD Forum | 4 | December 25, 2009 08:25 |
spline interpolation | bajjal | Main CFD Forum | 0 | May 29, 2006 09:27 |
Interpolation for ghost cell help | zonexo | Main CFD Forum | 0 | March 11, 2006 21:03 |
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 | Amitava Majumdar | Main CFD Forum | 0 | January 5, 1999 13:00 |
