August 25, 2009, 13:48 |
Development of a Low mach PISO solver
Nishant
Rep Power: 17 |
Hi Foamers
I am trying to develop a low mach number subsonic solver based on original PISO. Since PISO claimed to solve upto mach number as low as 0.001, therefore I have started with the sonicFoam solver and changed the solver to solve PISO for subsonic flow. Changes are: 1. The energy equation is coupled with the pressure equation to solve it iteratively. (as mentioned in the original PISO) 2. The pressure equation is changed and reference is taken from other subsonic solver. (like XiFoam, as suggested by Henery Weller) 3. solution of continuity equation at the start of iteration is abandoned to preserve the pressure fluctuation at low mach number which would die otherwise. the source file is attached herewith. see the attachment below. I have tested this solver with plane channel flow and result are good. I have checked it with forward step problem also. Let me know if this solver is corrected changed? or if there is any improvement you can suggest then Please make some comment on it. with regards, Nishant |
Steady State All Mach Numbers Solver | mkraposhin | OpenFOAM Running, Solving & CFD | 0 | March 9, 2009 04:22 |
Can a compressible solver solve incompressible ? | jinwon park | Main CFD Forum | 17 | December 13, 2007 06:00 |
The Far-field Pressure Boundary & Low Mach Number | Saif-Deen Akanni | FLUENT | 1 | March 5, 2007 06:05 |
Compressible code at low Mach numbers | Peter | Main CFD Forum | 7 | May 15, 2003 08:12 |
TVD scheme at low Mach number | Axel Rohde | Main CFD Forum | 5 | August 6, 1999 03:01 |
