Calculating YPLUS and Compiling Multiple C files
Old   August 10, 2009, 08:07
Default Calculating YPLUS and Compiling Multiple C files
Sanjib Das Sharma
sanjibdsharma is on a distinguished road
I am new to OpenFoam and trying to determine YPlus values from Turbulent flow. I found the yPlusRAS.C file. However, I do not know how to compile this along with any other flow solver, for eg. simpleFoam.C. I have tried to change the Make file in the solver as:
simpleFoam.C
yPlusRAS.C
EXE = $(USER_APP_BIN)/ simpleFoam
But this did not work.
Can anyone suggest a way to determine YPlus and also how to compile multiple C files in OpenFoam.
Thanks a lot in advance.
Sanjib
sanjibdsharma is offline   Reply With Quote
Old   August 11, 2009, 07:56
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
This doesn't really make sense. Do you want to calculate yPlus values for post processing, or do you need them during the calculation?
Look inside yPlusRAS.C. If you want to calculate a field of yPlus values, you'll see on line 54 that the field is declared and initialised. On line 99, the yPlus values are calculated. You'll see that they come from RASModel.
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
