Unit normal vector of nearest wall
Old   August 3, 2009, 07:17
Default Unit normal vector of nearest wall
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
I'm looking to implement a wall lubrication force for multiphase flow. For this I need the unit vector normal of the nearest wall.
I found reflectionVector, and that gives the unit vector normal at the wall. Is there a function to give the unit vector normal of the nearest wall?
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Old   August 4, 2009, 03:40
Hrvoje Jasak
Yes, this is precisely what you need.
It is used in wall reflection terms in Reynolds stress transport turbulence models.
Enjoy,
Hrv
Hrvoje Jasak
Old   August 4, 2009, 05:52
Ah, wallDistReflection! I somehow missed the fact that it inherits from reflectionVector in the class reference. Thank you for the gentle nudge in the right direction.
Old   May 13, 2014, 18:06
CHARLES
CHARLES is on a distinguished road
I know that wallDistReflection is what I need to use but I'm not sure how I would use it. Can you please give me an example of how you would implement it in the code?
Thanks!
CHARLES is offline   Reply With Quote
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 16:33
UDF to Access Wall Normal Concentration Gradient Daniel Tanner Fluent UDF and Scheme Programming 4 February 18, 2015 15:35
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 16:57
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
