puzzled
Old   July 21, 2009, 08:36
Default puzzled
Antonio Martins
titio is on a distinguished road
Send a message via MSN to titio Send a message via Skype™ to titio
Hi Foamers,
I am puzzled, and can say dissapointed by the discovery of the huge differences that exist between the public version and the development version. I believe this is limiting a faster development of the code and of its users base. I know that it is not easy to develop good code, but, in this way it may seem that some people is hidding new developments from other people, or limiting the development of OpenFoam by any other reasons.
Regards,
Titio
titio is offline   Reply With Quote
Old   July 21, 2009, 09:05
John Deas
johndeas is on a distinguished road
The -dev is not a development version of what you find on the OpenCFD website. It is a separate project, you can find more info on this forum. The teams behind OpenCFD and -dev are separate and do not work closely.
Or I have not understood it well myself.
johndeas is offline   Reply With Quote
Old   July 21, 2009, 12:54
Alberto Passalacqua
John is right. The two versions are developed and maintained by two separate groups. I know there is an effort to base the -dev version on the one from OpenCFD though, so the common base should be very similar if not identical.
This said, even if I don't find the situation ideal at all myself, I also think developers can do what they like with their code, and users are free to use it or not, choosing according to their needs.
Alberto Passalacqua
Old   July 21, 2009, 14:17
Henrik Rusche
henrik is on a distinguished road
Dear Titio,
the OpenFOAM-extend admins are working towards making the situation more transparent to users, especially new ones. In the meantime, please have a look at this presentation held at the OpenFOAM Workshop in Montreal
http://www.openfoamworkshop.org/2009...OAM_extend.pdf
There are also many threads on this forum that deal with this topic.
Regards, Henrik
henrik is offline   Reply With Quote
Old   June 14, 2010, 11:24
Default A Question about source codes
Gaurav
PaGgiE is on a distinguished road
I am a newbie to OpenFOAM. I am getting started with a case of an obstacle in path of fluid flow. As known, OpenFOAM is open source. But I am not able to locate where the codes of different functions, which are used in the solvers, are written?
eg. in icoFOAM solver, the function adjustPhi(), solve() are used.
similarly in other solvers also.
Someone guide me through it please.
Gaurav
PaGgiE is offline   Reply With Quote
Old   June 14, 2010, 14:12
Alberto Passalacqua
you can use the Doxygen documentation to look for functions, or simply do a search inside the files using KDE or GNOME functionalities for example.
For adjustPhi:
For solve method, start from here, for example: http://foam.sourceforge.net/doc/Doxy...93626ca630a050
Best,
Alberto Passalacqua
Old   June 16, 2010, 06:47
Gaurav
Thanks for the help Alberto.
Puzzled by multi-block solver implementation...... Chen Zhi Main CFD Forum 3 February 14, 2010 21:10
CFX and ICEM CFD - structured meshes realanony87 CFX 10 May 15, 2009 06:17
Linking libraries with wmake hemph OpenFOAM 5 November 13, 2006 05:12
