LES Dynamic models details
Old   July 18, 2009, 04:19
Default LES Dynamic models details
lakeat's Avatar
Daniel WEI (老魏)
lakeat is on a distinguished road
Send a message via Skype™ to lakeat
Dear all,
If I am not mistaken, the current dynamic models calculate the coefficients as a single scalar, not scalarfield, I mean C is not C(y), or C(x,y,z,t). The averaging process is not done in homogeneous directions.
I am a little confused, the original basic idea of Dynamic procedure would make sense better if averaging in homogeneous directions, wouldn't it?
Another question I have is, is the test filter used in OpenFOAM double size of the original filter? If I am not mistaken, simpleFilter is just another explicit filter used in dynamic procedure that differs from the implicit filter, but isn't the explicit simpleFilter (top-hat) the same as the implicit filter (top-hat too!)?
Please correct me if I was wrong.
Thank you very much.
Daniel WEI
Boeing Research & Technology - China
Beijing, China
Email
lakeat is offline   Reply With Quote
Old   July 20, 2009, 10:46
Default dynOneEqEddy vs locDynOneEqEddy
Michael Roth
roth is on a distinguished road
Take a look at the source of "locDynOneEqEddy" which is a localized, dynamic LES model i.e C(x,y,z,t).
Contrast this with "dynOneEqEddy" which is dynamic but with a global coefficient i.e C(t).
Michael
roth is offline   Reply With Quote
Old   July 24, 2009, 06:15
lakeat's Avatar
Daniel WEI (老魏)
I see, but what about the second question,
"is the test filter used in OpenFOAM double size of the original filter?"
Thank you, Michael!
Daniel WEI
Beijing, China
Email
Old   September 2, 2009, 09:05
Post
W.L.Zhang
fluidzhang is on a distinguished road
the ratio of the two filter width is 2,this number was choosed by some researchers,they demonstrated it was optimum.
fluidzhang is offline   Reply With Quote
Old   September 2, 2009, 09:17
lakeat's Avatar
Daniel WEI (老魏)
Which line in the source code, please?
Daniel WEI
Beijing, China
Email
Old   January 18, 2011, 17:28
Matt James
mdjames is on a distinguished road
the test filter size is (at least in dynSmag) controlled by the variable ce in the turbulenceProperties dict, I think.
mdjames is offline   Reply With Quote
Old   January 24, 2011, 11:16
StSchiff
The test filter width is set to twice the grid filter width by the following line in dynSmagorinsky:
volSymmTensorField MM =
sqr(delta())*(filter_(mag(D)*(D)) - 4*mag(filter_(D))*filter_(D));
The factor 4 results from substituting 2*delta for the test filter width. where delta is the grid filter width.
Old   April 6, 2011, 12:43
Francois
Fransje will become famous soon enough
If I'm not mistaken, I think even the locDynOneEqEddy model is not localized..
EDIT: I stand corrected. The coefficients are volScalarFields, so that would imply local coefficients..
Fransje is offline   Reply With Quote
Old   April 6, 2011, 15:23
lakeat's Avatar
Daniel WEI (老魏)
Well, you have to give it some sort of name
Daniel WEI
Beijing, China
Email
Old   April 6, 2011, 15:41
lakeat's Avatar
Daniel WEI (老魏)
And I just don;t believe there is an universal shortcut to model all types or turbulence in a non-DNS mesh.
Personally, I think the development of LES small scale turbulence models has almost reached its peak.
But it seems hybrid method still has a long way to go.
Daniel WEI
Beijing, China
Email
Old   May 19, 2011, 08:46
Default Test filter
  #11
longamon's Avatar
David Aljure
Location: CTTC Universidad Politécnica de Catalunya. Spain
longamon is on a distinguished road
moved to new thread
longamon is offline   Reply With Quote
Failed dimensional check with dynamic LES models alberto OpenFOAM Bugs 9 September 5, 2007 23:57
LES dynamic models fail dimensional check alberto OpenFOAM Running, Solving & CFD 0 June 11, 2007 14:23
user subroutine error CFDUSER CFX 2 December 9, 2006 07:31
user defined function cfduser CFX 0 April 29, 2006 11:58
Nan on LES dynamic models sampaio OpenFOAM Running, Solving & CFD 10 March 8, 2005 16:44
