coordinate depending source term
Old   July 10, 2009, 07:54
Default coordinate depending source term
Jagmohan Meena
jmmeena is on a distinguished road
Dear Sir/Madam,
I am doing a heat transfer problem with source term. Source term itself depends on the x,y,z, coordinates. I have tried following :
Teqn:
fvScalarMatrix TEqn
(rho)*(Cp)*fvm::ddt(T)
+ fvm::div(phi, T)
- (rho)*(Cp)*fvm::laplacian(DT, T)
Q
TEqn.relax();
eqnResidual = TEqn.solve().initialResidual();
maxResidual = max(eqnResidual, maxResidual);
Q is source term which is defined as:
Info<< "Reading sourceProperties\n" << endl;
IOdictionary sourceProperties
IOobject
"sourceProperties",
runTime.constant(),
mesh,
IOobject::MUST_READ,
IOobject::NO_WRITE
dimensionedScalar Acos
sourceProperties.lookup("Acos")
dimensionedScalar Rcos
sourceProperties.lookup("Rcos")
dimensionedScalar Zcos
sourceProperties.lookup("Zcos")
dimensionedScalar Q("Q", Acos*cos(0.5*3.14*(sqrt((x[0]*x[0])+(x[1]*x[1])))/Rcos)*cos(0.5*3.14*x[2]/Zcos));
if (Q < 0.)
Q = 0.0;
Error:
readSourceProperties.H: In function ‘int main(int, char**)’:
readSourceProperties.H:30: erreur: ‘x’ was not declared in this scope
readSourceProperties.H:32: erreur: no match for ‘operator<’ in ‘Q < 0.0’
make: *** [Make/linux64GccDPOpt/sourceBuoyantSimpleFoam.o] Erreur 1
I thought to use x[0] for x, x[1] for y and x[2] for z ! but OpenFOAM reports error in this. Hence my question is: How to input coordinates for Q so that it OpenFOAM will understand it ?
thankyou in advance !!
regards,
JM
jmmeena is offline   Reply With Quote
momentum source term zwdi FLUENT 14 June 27, 2017 16:40
coordinate depending source term jmmeena OpenFOAM 6 July 15, 2009 06:18
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 14, 2000 00:03
