Using ODE in OpenFoam
Like Tree10Likes
Old   March 29, 2016, 18:55
Default Problems with ODE in OpenFOAM 2.4.x?
  #21
Mauricio
mauri_tano is on a distinguished road
Hello guys,
I am trying to implement an ODE solver for an application. For getting familiarized with the available solvers, I tried to run the Test-ODE script from $FOAM_APP/test/ODE.
I run
wmake
and it compiles fine, making the correct dependencies. However, when I tried to execute it, running for example
 Test-ODE Euler
I get just line with the following error:
 Segmentation Fault (`core' generated)
I have tried changing the solvers with equal results. I will very much appreciate your recommendations
Thanks a lot!
Mauricio.
mauri_tano is offline   Reply With Quote
Old   March 30, 2016, 10:06
Hassan Kassem
hk318i is on a distinguished road
Try to use wclean then wmake. If it didn't work, go to src/ODE and wclean then wmake the ODE library.
This error is related to your machine and OF installation. I couldn't reproduce it.
hk318i is offline   Reply With Quote
Old   April 6, 2022, 07:05
zink
ansab_sindhu is on a distinguished road
hi,
The links mentioned in the below post are not working, can anyone share the alternative one please?
Regarding the forces class, it is not only for writing. You can use it to get the forces directly [LINK].
There is a very good example for that in OpenFOAM source in sixDoFRigidBody [LINK] library. Here is a snippet of this library;
Originally Posted by hk318i View Post
Hello Methma,
That is a great progress, well done.
// define a dictionary first
    dictionary forcesDict;
// add the required parameters
    forcesDict.add("type", forces::typeName);
    forcesDict.add("patches", wordList(1, ptPatch.name()));
    forcesDict.add("rhoInf", rhoInf_);
    forcesDict.add("rhoName", rhoName_);
    forcesDict.add("CofR", motion_.centreOfRotation());
// create force object
    forces f("forces", db(), forcesDict);
// calculate the forces
    f.calcForcesMoment();
// finally you can get the forces and moment
    vector F = f.forceEff();
    vector M = f.momentEff();
Best wishes,
Hassan
ansab_sindhu is offline   Reply With Quote
Is GUI there for OpenFoam navaladi OpenFOAM 4 September 11, 2023 14:35
OpenFoam vs CFX5 mass balance in OpenFoam tangd OpenFOAM Running, Solving & CFD 33 May 23, 2010 17:36
[blockMesh] CheckMesh error using a tutorial from OpenFOAM 114 with openFOAM 13 martapajon OpenFOAM Meshing & Mesh Conversion 7 January 21, 2008 13:52
OpenFOAM users in Munich OpenFOAM benutzer in M%c3%bcnchen jaswi OpenFOAM 0 August 3, 2007 14:11
A new Howto on the OpenFOAM Wiki Compiling OpenFOAM under Unix mbeaudoin OpenFOAM Installation 2 April 28, 2006 09:54
