codedMixed temperature in compressibleInterFoam |
December 13, 2024, 15:54 |
Julio Pieri
Rep Power: 9 |
Dear all,
I'm running a simulation (high pressure gas injected into water) in which T varies at the inlet with a codedMixed BC, with OF2212. The coded part itself is ok, and the T value is updated correctly. However, the T.gas field is not updated with the coded T during the simulation - it is kept constant as the initialized value. This leads to a wrong rho, thus changing the inlet mass flow rate and giving wrong results. Only when I stop and resume the simulation the T.gas field is updated to the proper value of T (which was freshly calculated from the coded BC at the begining of the run, during 'mixture' construction). Did anyone face problems like this one? Is there any workaround? I believe the thermo1 and thermo2 objects should be updated form T every timestep, but for some reason it isn't. Thanks! Last edited by JulioPieri; December 13, 2024 at 17:28. |
December 16, 2024, 13:23 |
Julio Pieri
Rep Power: 9 |
For those interested in something similar, it seems to be a bug with ESI OF. Running in Foundation v11 did the trick.
coded, codedmixed, compressibleinterfoam, temperature |
Outlet temperature to temperature boundary condition of velocity inlet. (UDF) | dillon | Fluent UDF and Scheme Programming | 3 | March 25, 2018 12:06 |
Static temperature and Total temperature | Jong-Yoon | FLUENT | 0 | September 25, 2016 02:42 |
Free stream temperature | saharesobh | FLUENT | 1 | October 11, 2012 21:52 |
How to get free stream temperature in boundary condition | saharesobh | FLUENT | 0 | October 9, 2012 18:12 |
monitoring point of total temperature | rogbrito | FLUENT | 0 | June 21, 2009 18:31 |
