multiphaseInterFoam : add terms to volume fraction equation |
December 12, 2024, 06:44 |
Nicholas Langbein
Rep Power: 2 |
I want to add a convection and diffusion term (strain rate dependent) to volume fraction equation to advect a particular phase in certain direction.. In the source code of VoF alphaEqn.H i tried adding a convection and diffusion flux ... but even with MULES alpha values blows up crazy. Is there a standard procedure or reference on how to add terms to alphaEqn.H (i cant use alphaSource because my terms are strainrate dependent) Should or how can i make it Implicit |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 22:43 |
Foam::error::printStack(Foam::Ostream&) in compressibleInterFoam | JM27 | OpenFOAM Running, Solving & CFD | 2 | May 26, 2020 09:13 |
[PyFoam] and paraview | eelcovv | OpenFOAM Community Contributions | 28 | May 30, 2016 10:23 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 06:42 |
Solving the Volume Fraction Equation in a Multiphase M. | Max585 | FLUENT | 1 | March 20, 2012 08:49 |
