Error when compiling custom solver for an arc flash simulation
Old   December 11, 2024, 09:43
Post Error when compiling custom solver for an arc flash simulation
Gerald
geraldnjw is on a distinguished road
Hello all!
I am trying to simulate the pressure distribution in a room due to an arc flash using a custom solver I am modifying from rhoCentralFoam. I am treating the arc flash as a heat source and want to add the energy released as a source term Q, where Q=kp*Warc.
I added this in the createFields.H file:
IOdictionary arcProperties
    IOobject
        "arcProperties",
        runTime.constant(),
        mesh,
        IOobject::MUST_READ,
        IOobject::NO_WRITE
dimensionedScalar kp
	"kp",
	dimless,
	arcProperties.lookup("kp"),
dimensionedScalar Warc
	"kp",
	dimEnergy,
	arcProperties.lookup("Warc"),
volScalarField Q
    IOobject
        "Q",
        runTime.timeName(),
        mesh,
        IOobject::NO_READ,
        IOobject::NO_WRITE
    kp*Warc,
While compiling the source code i encountered these errors.
Making dependencies: AFRhoCentralFoam.C
g++ -std=c++14 -m64 -pthread -DOPENFOAM=2406 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3  -DNoRepository -ftemplate-depth-100  -IBCs/lnInclude -I/usr/lib/openfoam/openfoam2406/src/finiteVolume/lnInclude -I/usr/lib/openfoam/openfoam2406/src/meshTools/lnInclude -I/usr/lib/openfoam/openfoam2406/src/transportModels/compressible/lnInclude -I/usr/lib/openfoam/openfoam2406/src/thermophysicalModels/basic/lnInclude -I/usr/lib/openfoam/openfoam2406/src/thermophysicalModels/specie/lnInclude -I/usr/lib/openfoam/openfoam2406/src/TurbulenceModels/turbulenceModels/lnInclude -I/usr/lib/openfoam/openfoam2406/src/TurbulenceModels/compressible/lnInclude -I/usr/lib/openfoam/openfoam2406/src/dynamicFvMesh/lnInclude -iquote. -IlnInclude -I/usr/lib/openfoam/openfoam2406/src/OpenFOAM/lnInclude -I/usr/lib/openfoam/openfoam2406/src/OSspecific/POSIX/lnInclude   -fPIC -c AFRhoCentralFoam.C -o Make/linux64GccDPInt32Opt/AFRhoCentralFoam.o
In file included from /usr/lib/openfoam/openfoam2406/src/OpenFOAM/lnInclude/postProcess.H:147,
                 from AFRhoCentralFoam.C:61:
./createFields.H: In function ‘int main(int, char**)’:
./createFields.H:121:1: error: expected primary-expression before ‘)’ token
  121 | );
./createFields.H:128:1: error: expected primary-expression before ‘)’ token
  128 | );
./createFields.H:141:1: error: expected primary-expression before ‘)’ token
  141 | );
In file included from AFRhoCentralFoam.C:67:
  121 | );
  128 | );
  141 | );
make: *** [/usr/lib/openfoam/openfoam2406/wmake/rules/General/transform:38: Make/linux64GccDPInt32Opt/AFRhoCentralFoam.o] Error 1
Does anyone know the cause of these errors and/or how to resolve them? Any help would be greatly appreciated! I am using openfoam v2406.
geraldnjw is offline   Reply With Quote
Old   Today, 06:02
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Why do you have a trailing comma after each of the last parameters? This is not good.
olesen is offline   Reply With Quote
heat source term, rhocentralfoam
Divergence detected in AMG solver. VOF. Mr.Mister Fluent Multiphase 5 November 22, 2024 07:32
CPUs vs GPUs for CFD? hami11 Hardware 22 July 23, 2024 16:59
viscosity udf don't use correct temperature and strain rate rezvani Fluent UDF and Scheme Programming 8 May 27, 2021 06:40
[blockMesh] Meshing a circle in a square ChasingNeutrons OpenFOAM Meshing & Mesh Conversion 6 October 11, 2016 21:42
settlingFoam unstable? bendel_boy OpenFOAM Running, Solving & CFD 38 July 8, 2016 06:07
