Implement new drag models in multiphaseEulerFoam while floating point exception |
December 2, 2024, 03:29 |
Dear foamers,
I implement this drag model in openfoam10 solver multiphaseEulerFoam, C_D=\frac{4.4}{Re^{1.42}}(1+0.196Ar^{0.381})(1+Eo) ^{0.78}Mo^{-0.15} And this is my code: HTML Code:
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Copyright (C) 2014-2022 OpenFOAM Foundation \\/ M anipulation | ------------------------------------------------------------------------------- License This file is part of OpenFOAM. OpenFOAM is free software: you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free Software Foundation, either version 3 of the License, or (at your option) any later version. OpenFOAM is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details. You should have received a copy of the GNU General Public License along with OpenFOAM. If not, see <http://www.gnu.org/licenses/>. \*---------------------------------------------------------------------------*/ #include "Hosen.H" #include "aspectRatioModel.H" #include "addToRunTimeSelectionTable.H" // * * * * * * * * * * * * * * Static Data Members * * * * * * * * * * * * * // namespace Foam { namespace dragModels { defineTypeNameAndDebug(Hosen, 0); addToRunTimeSelectionTable(dragModel, Hosen, dictionary); } } // * * * * * * * * * * * * * * * * Constructors * * * * * * * * * * * * * * // Foam::dragModels::Hosen::Hosen ( const dictionary& dict, const phaseInterface& interface, const bool registerObject ) : dispersedDragModel(dict, interface, registerObject), residualRe_("residualRe", dimless, dict), residualMo_("residualMo", dimless, dict) {} // * * * * * * * * * * * * * * * * Destructor * * * * * * * * * * * * * * * // Foam::dragModels::Hosen::~Hosen() {} // * * * * * * * * * * * * * * * Member Functions * * * * * * * * * * * * * // Foam::tmp<Foam::volScalarField> Foam::dragModels::Hosen::CdRe() const { volScalarField Eo(interface_.Eo()); volScalarField Mo(max(interface_.Mo(), residualMo_)); volScalarField Re(max(interface_.Re(), residualRe_)); volScalarField Ar(interface_.Ar()); return (4.4/pow(Re,1.42)*(1+0.196*pow(Ar,0.381))*pow((1+Eo),0.78)*pow(Mo,-0.15)); } // ************************************************************************* // HTML Code:
Create time Create mesh for time = 0 PIMPLE: No convergence criteria found PIMPLE: No corrector convergence criteria found Calculations will do 3 corrections PIMPLE: Operating solver in transient mode with 3 outer correctors Reading g Reading hRef Creating phaseSystem Selecting phaseSystem basicMultiphaseSystem Selecting phaseModel for air: purePhaseModel Selecting diameterModel for phase air: constant Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleInternalEnergy; } Calculating face flux field phi.air Selecting turbulence model type laminar Selecting laminar stress model Stokes Selecting thermophysical transport type laminar Selecting default laminar thermophysical transport model unityLewisFourier Selecting phaseModel for water: purePhaseModel Selecting diameterModel for phase water: constant Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport const; thermo eConst; equationOfState rPolynomial; specie specie; energy sensibleInternalEnergy; } Calculating face flux field phi.water Selecting turbulence model type laminar Selecting laminar stress model Stokes Selecting thermophysical transport type laminar Selecting default laminar thermophysical transport model unityLewisFourier No MRF models present Selecting surfaceTensionModel for air_water: constant Selecting dragModel blending method for air_water: continuous Selecting dragModel for air_dispersedIn_water: Hosen Calculating field g.h Reading field p_rgh Creating fvConstraints from "system/fvConstraints" Selecting finite volume constraint type limitPressure Name: limitp min 10000 Courant Number mean: 0.000375 max: 0.000375 Starting time loop Courant Number mean: 0.000375 max: 0.000375 Time = 0.005s PIMPLE: Iteration 1 MULES: Solving for alpha.air air fraction, min, max = 1.25e-06 0 0.5 MULES: Solving for alpha.air air fraction, min, max = 2.5e-06 0 0.5 Constructing momentum equations #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::symGaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) at ??:? #4 Foam::symGaussSeidelSmoother::smooth(Foam::Field<double>&, Foam::Field<double> const&, unsigned char, int) const at ??:? #5 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #6 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:? #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/home/dyfluid/OpenFOAM/OpenFOAM-10/platforms/linux64GccDPInt32Opt/bin/multiphaseEulerFoam" #8 Foam::fvMatrix<double>::solve() in "/home/dyfluid/OpenFOAM/OpenFOAM-10/platforms/linux64GccDPInt32Opt/bin/multiphaseEulerFoam" #9 ? in "/home/dyfluid/OpenFOAM/OpenFOAM-10/platforms/linux64GccDPInt32Opt/bin/multiphaseEulerFoam" #10 ? in "/lib/x86_64-linux-gnu/libc.so.6" #11 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #12 ? in "/home/dyfluid/OpenFOAM/OpenFOAM-10/platforms/linux64GccDPInt32Opt/bin/multiphaseEulerFoam" Floating point exception (core dumped) |
December 6, 2024, 20:56 |
Amirhossein Taran
Rep Power: 10 |
There could be a couple of parameters causing this, To test the worst scenario, Could you re-compile the code without having Re at the denominator? If that worked, it means that Re is messing it up. If not, it means that this drag value is causing problems elsewhere in the model. Bests, Amir. |
December 11, 2024, 09:01 |
Rep Power: 8 |
1. probably division by 0 in Re, like @amirhosseintaran suggests. you can do something like min(Re, 1E-19).
2. keep in mind that in the code you have Cd*Re! but your formula is for Cd. |
December 11, 2024, 22:49 |
Thank you so much for your advice ,I missed Re in my formula ,after adding *Re in the formula, it all works well
bubble flow, drag forces, multiphase flow, multiphase model |
Error at Node 0: floating point exception | maybe | FLUENT | 0 | May 24, 2024 04:03 |
Floating point exception with multiphaseEulerFoam | Björnpork | OpenFOAM Running, Solving & CFD | 0 | June 14, 2023 10:06 |
A floating point exception - SEM Model | yansheng | STAR-CCM+ | 1 | April 4, 2016 05:57 |
Floating point exception from twoPhaseEulerFoam | openfoammaofnepo | OpenFOAM Running, Solving & CFD | 1 | March 19, 2016 14:56 |
[Gmsh] Gmsh and samplesurface | touf | OpenFOAM Meshing & Mesh Conversion | 2 | December 10, 2007 03:27 |
