November 21, 2024, 14:47 |
Calculating particle charging
Hello, I am trying to calculate the charge of particles moving in a space charge field. The idea is to create a variable in the Cloud.H that contains the charge per time step and can be read in the “kinematicCloudProperties” in a Coulomb force.
The calculation of the charge should be implemented in Cloud.H using a mathematical charging model. I have not been with OF for long and therefore do not know whether the procedure is correct/conducive. I have v2312. Is it possible to copy the Cloud.H file to my run directory and change and recompile it there? I am having difficulties with this. Thank you in advance for any feedback. Best regards |
openfoam, particle charging |
Calculating source term total cell-zone volume parallel computation | RobV | Fluent UDF and Scheme Programming | 2 | May 30, 2022 04:46 |
Particle tracking error | alchem | OpenFOAM Bugs | 5 | May 6, 2017 17:30 |
injection problem | Mark New | FLUENT | 0 | August 4, 2013 02:30 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 02:29 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 18:27 |
