Limit reaction to surface or set regions in fluid |
October 23, 2024, 05:59 |
Nicholas Gushiken
I'm trying to model a fluid-solid catalysis reaction using chtMultiRegionFoam, with the reaction happening only on the surface of the solid catalyst. To do that, my idea was to implement a scalar field reactionZone with value 1 in the part of the fluid region i want the reaction to happen, and 0 everywhere else. I have successfully implemented the scalar field in the solver, checking it in paraview to ensure it's set up correctly. Now, i have tried to implement the field in the reaction rates calculations, but with no success, although i can tell the field is being read correctly, and compiling without error. How and where should i go about changing the chemistry solvers to implement the field? Or is there another way to limit the reaction to happen only on the fluid-solid interface? |
catalysis, chemistry, multi region, reaction, scalar field |
reaction mechanism in fluid domain | Weiqiang Liu | FLUENT | 0 | April 6, 2019 12:25 |
Having problems setting up surface reaction, catalyst, adsorption and desorption | Juun | FLUENT | 12 | February 8, 2017 12:03 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 15:32 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
