Adding a temperature dependent FvOptions in ChtMultiRegionFoam for an electric oven
Old   October 16, 2024, 07:31
Default Adding a temperature dependent FvOptions in ChtMultiRegionFoam for an electric oven
Arunkl
arunkl is on a distinguished road
I am new to heat transfer solvers in openfoam and working to simulate an electric oven. in this there is four coils and air region. I am using chtMultiRegionFoam for this as it has multiple regions. I have came through Fvoptions which is time dependent but i need to model Temperature dependent so that if the mean temperature increases upto 250 C it should supply heat and turn off the heat source. Again if the temperature reduces it should on the heat source. I have attached the basic Coding i have done and thankyou in advance for your most thankful help... this is for natural convection to the air
options
    energySource
        type            scalarSemiImplicitSource;
        selectionMode   cellSet;
        cellSet         ignition;
        volumeMode      specific;
        sources
            h           (2e7 0);  // kg/m/s^3
        // Temperature-dependent behavior
        code
            // Get the mean temperature from the temperature field
            const scalar T_mean = T.mean();  // Assuming T is the temperature field variable
            // Check if T_mean exceeds 250 °C
            if (T_mean >= 250 + 273.15)  // Convert 250 °C to Kelvin
                return 0;  // Turn off the heat source if T_mean is 250 °C or higher
            else
                // Return the source value only if the temperature is below 250 °C
                return h;  // Return the defined source value
if there any mistake kindly feel free to say in the thread and it would be very helpful and the version used is ise version v2212
thank you
arunkl is offline   Reply With Quote
cht modelling, chtmultiregion, chtmultiregionfoam, heat and mass transfer, openfoam
[openSmoke] libOpenSMOKE Tobi OpenFOAM Community Contributions 562 January 25, 2023 10:21
Averaging over iterations for steady-state simulation CFD student Fluent UDF and Scheme Programming 8 September 22, 2022 04:39
Help with chtMultiRegionFoam jbvw96 OpenFOAM Running, Solving & CFD 2 December 26, 2010 18:16
Adding a new temperature dependent viscositymodel? dgadensg OpenFOAM Programming & Development 10 May 22, 2010 06:47
flow simulation across a small fan jane luo Main CFD Forum 15 April 12, 2004 18:49
