Help with changing static pressure at patch due to calculated mass flow rate at patch |
October 10, 2024, 12:22 |
TWB
Rep Power: 19 |
I need change static pressure at a patch due to calculated mass flow rate at that patch when OF is running. So I need to do 2 things - 1. calculate mass flow rate at a patch, maybe every 10 or 50 steps or time interval 2. based on the mass flow, change the static pressure at tt patch based on some formula. FYI, I'll be using rhoSimpleFoam. I read that one can change BC thru changeDictionaryDict. But I'm not sure if this is the right way. Thanks. |
Wind tunnel Boundary Conditions in Fluent | metmet | FLUENT | 6 | October 30, 2019 13:23 |
mass flow inlet and pressure outlet with target mass flow rate | Zigainer | FLUENT | 13 | October 26, 2018 06:58 |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 18:34 |
static pressure from mass flow rate | mukhtarjussa | FLUENT | 0 | April 12, 2010 11:39 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 06:12 |
