codeStream - Break with constant torque: OFv2206 |
October 4, 2024, 18:52 |
I am simulating a marine turbine rotating due to incoming flow. I am trying to implement a break that applies a constant torque on a shaft using codeStream as a rigidBodyMotion restraint within a dynamicMeshDict. The sign of the torque depends only on the direction of rotation. I tried to follow some codeStream examples without success. Code:
restraints { breakTorque { type externalForce; body Turbine; location (1.0 0 0.11432977); force #codeStream { codeInclude #{ // #include "rigidBodyState.H" #include "rigidBodyMotion.H" // #include "rigidBodyMeshMotion.H" #}; codeOptions #{ -I$(LIB_SRC)/rigidBodyDynamics/lnInclude \ // -I$(LIB_SRC)/rigidBodyMeshMotion/lnInclude #}; codeLibs #{ -lrigidBodyDynamics // -lrigidBodyMeshMotion #}; code #{ scalar omega = vCofR.w(v(0,Zero))[2] torque = 16.0 if (omega < 0) { os << (0 torque 0.0) } else { os << (0 -torque 0.0) } #}; }; } } Any suggestion will be appreciated. Ruben
R. |
Chemical properties that are used in Fluent | kimej | FLUENT | 4 | August 19, 2011 12:29 |
How to install CGNS under windows xp? | lzgwhy | Main CFD Forum | 1 | January 11, 2011 19:44 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 07:25 |
Really big problems when creating own materials da | Jop | FLUENT | 0 | June 28, 2007 12:15 |
net torque | Mangnan | CFX | 3 | June 2, 2004 15:00 |
