September 4, 2024, 08:32 |
Inspecting case structure
Juan Pablo Carbajal
Rep Power: 5 |
Dear all,
Quite often we are faced with the following questions: 1. Given a dictionary file name (e.g. controlDict) where does it belong in the case folder structure? 2. Given a table/entry name (e.g. massSource) in which dictionary files can bit be placed? 3. Given a solver name (e.g. fluid) what dictionary files will it parse? We have try to answer these with the foamToC application, but it seems to answer the question: 4. Given a solver what table/entries can it consume? And the question of where to put those is left unanswered. Sometimes it helps to read the documentation of the given table/entry retrieved by foamInfo. Is there a way to answer question 1-3 programmatically. That is, other than manual exploration of output of foamInfo, searching the tutorials, or reading the source code? To help us to partially answer the questions we use a database that we build by scanning the $FOAM_TUTORIALS folder (we exclude multi region cases). The database we built for OF.org v12 is attached. Thank you very much for any input provided |
case setup, folders and files |
Fluid structure analysis of 2D airfoil case | ahsan_smme.nust@yahoo.com | OpenFOAM | 0 | April 22, 2014 06:12 |
Divergence with a flexible structure in a FSI case | Zymon | CFX | 14 | January 26, 2012 08:33 |
Error reading new case | montag dp | FLUENT | 5 | September 15, 2011 06:00 |
Generic case structure for iterative design process | capucsc | OpenFOAM | 4 | May 6, 2011 11:26 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
