Functionality tabulated6DoFMotion in OPenFoam12 |
September 2, 2024, 14:32 |
BabuG
Rep Power: 2 |
Dears,
I wanted to use the functionality "tabulated6DoFMotion" which is listed in the following path. https://openfoamwiki.net/index.php/P...dyMotionFvMesh In OpenFoam 10 or earlier versions, underpath: opt\openfoam12\src\motionSolvers\displacement\soli dBody\solidBodyMotionFunctions There is a folder for time based interpolation: tabulated6DoFMotion This is not available in OpenFoam 12. I would like to add this to my user version somehow. I got the files tabulated6DoFMotion.C and tabulated6DoFMotion.H from google search See following link https://cpp.openfoam.org/v10/interpo...8C_source.html So I copied these files and tried to compile in ubuntu 24.04. I am facing compilation issues. All errors are shown from these 2 files. In a nut shell, I wanted to use the tabulated6DoFMotion for my work How to compile my user version with this functionality Further, as OpenFoam12 is an advanced version, there might be some modification done, and this functionality could have been included or implemented in some other functionality. If so, please guide me. Further If you have any ideas, please share me with regards papaji |
September 13, 2024, 04:06 |
Jan
Rep Power: 20 |
some years ago, it was replaced with a more general approach using function1. See: Code:
commit bfedfcde552ede13c3ebe112ab3d4186b65e2956 Author: Henry Weller <http://cfd.direct> Date: Fri Nov 13 21:12:15 2020 +0000 dynamicMesh::sixDoFMotion: Generalised replacement for tabulated6DoFMotion using Function1 and supporting all the standard Function1s including tabulated and coded. tutorials/multiphase/interFoam/laminar/sloshingTank3D6DoF updated to use sixDoFMotion. Jan |
September 15, 2024, 14:53 |
BabuG
Rep Power: 2 |
Hi JNSN,
Thank you for your help. I will explore it and convey my observations. Thank you |
[OpenFOAM.com] complile v2006 with runTimePostProcessing functionality | snak | OpenFOAM Installation | 2 | August 1, 2020 09:08 |
Multiphase ramping functionality | sita | OpenFOAM Running, Solving & CFD | 7 | September 18, 2019 14:03 |
postProcess functionality in openFOAM 4 and total(p) | LVDH | OpenFOAM Post-Processing | 3 | August 9, 2017 10:11 |
face functionality for a DynamicList | tomislav_maric | OpenFOAM Programming & Development | 2 | November 30, 2011 19:04 |
Excel like goal-seek type functionality in OpenFOAM | benk | OpenFOAM | 3 | April 30, 2010 17:50 |
