August 25, 2024, 10:27 |
Keyword sigmas underdefine
Deny
Rep Power: 2 |
Hello to All the team members
I hope you are having the good weekends and sorry to bother you in the weekends. I am using the compressibleMultiphaseVoF solver for helical pipe simulation, and I am getting the following error message. --> FOAM FATAL IO ERROR: keyword sigmas is undefined in dictionary "/home/OpenFOAM/research_mesh_convergence/research_10k_comVOF/constant/phaseProperties" Here below is my phaseProperties file /--------------------------------- C++ -----------------------------------\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 11 \\/ M anipulation | \---------------------------------------------------------------------------/ FoamFile { format ascii; class dictionary; location "constant"; object phaseProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // type interfaceCompositionPhaseChangeMultiphaseSystem; phases (gas liquid); gas { type multicomponentPhaseModel; diameterModel isothermal; isothermalCoeffs { d0 1.6e-3; //sauter mean diameter of bubbles (change this when known) p0 1e5; //atmospheric pressure } residualAlpha 1e-6; //convergence criteria } liquid { type multicomponentPhaseModel; diameterModel constant; constantCoeffs { d 1e-4; } residualAlpha 1e-6; } blending { default { type linear; minFullyContinuousAlpha.gas 0.7; minPartlyContinuousAlpha.gas 0.3; minFullyContinuousAlpha.liquid 0.7; minPartlyContinuousAlpha.liquid 0.3; } heatTransfer { type linear; minFullyContinuousAlpha.gas 1; minPartlyContinuousAlpha.gas 0; minFullyContinuousAlpha.liquid 1; minPartlyContinuousAlpha.liquid 0; } diffusiveMassTransfer { $heatTransfer; } } surfaceTension { gas_liquid { type constant; sigma 0.073; //0.0728 from engineering toolbox at 20C } } drag { gas_dispersedIn_liquid { type SchillerNaumann; } liquid_dispersedIn_gas { type SchillerNaumann; } } virtualMass { gas_dispersedIn_liquid { type constantCoefficient; Cvm 0.5; } liquid_dispersedIn_gas { type constantCoefficient; Cvm 0.5; } } interfaceComposition { gas_liquid_inThe_gas // model for water becoming dissolved in the air { type saturated; species ( water ); Le 1.0; pSat ArdenBuck; } gas_liquid_inThe_liquid // model for o2 and n2 becoming dissolved in the water { type Henry; species ( N2 O2 ); k (1.5e-2 3.2e-2); //dimensionless solubility constants for N2 and O2. Valid for temperatures around 280-300K Le 1.0; //Lewis number. leave at 1.0 ////SATURATED O2 at 20C is 9.1 mg/kg. (verfieid saturation with simulations!) ////SATURATED N2 at 20C is around 14 mg/kg. (verified saturation with simulations!) } } heatTransfer { gas_dispersedIn_liquid_inThe_gas { type spherical; residualAlpha 1e-4; } liquid_dispersedIn_gas_inThe_gas { type RanzMarshall; residualAlpha 1e-4; } gas_dispersedIn_liquid_inThe_liquid { type RanzMarshall; residualAlpha 1e-4; } liquid_dispersedIn_gas_inThe_liquid { type spherical; residualAlpha 1e-4; } } diffusiveMassTransfer { gas_dispersedIn_liquid_inThe_gas { type spherical; } liquid_dispersedIn_gas_inThe_gas { type Frossling; Le 1.0; } gas_dispersedIn_liquid_inThe_liquid { type Frossling; Le 1.0; } liquid_dispersedIn_gas_inThe_liquid { type spherical; } } phaseTransfer {} lift {} wallLubrication {} turbulentDispersion {} interfaceCompression {} // ************************* // I can see the sigma is define in the surface_tension section but I don't know why I am getting the error. Any help would be greatly appreciated. Regards Chintan |
compressiblemultiphasevof, multiphase simulation, phaseproperties, sigma error |
codeStream how to read a dictionary keyword in another file | reverseila | OpenFOAM Programming & Development | 3 | March 16, 2024 06:45 |
Accessing foamDictionary keyword ".*" | Tobermory | OpenFOAM Running, Solving & CFD | 3 | March 5, 2021 16:46 |
[solids4Foam] SOLVED: Paraview can't read solids files (duplicate entries with keyword value) | tschenkel | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 11 | March 23, 2020 04:48 |
Derivative of velocity and mean velocity | hiuluom | OpenFOAM Post-Processing | 1 | May 29, 2015 23:42 |
simpleFoam in parallel issue | plucas | OpenFOAM Running, Solving & CFD | 3 | July 17, 2013 11:30 |
