To know how to assign diffusion in different directions for interMinxingFoam
Old   August 22, 2024, 21:58
Default To know how to assign diffusion in different directions for interMinxingFoam
Charitha Rangana Dissanayaka
Charitha_Dissanayaka is on a distinguished road
Dear All,
I need your help to solve the following matter.
I used interMixingFoam to simulate landslide in OpenFOAM-4.x. But I have observed some strange result between the phases of alpha2 and alpha3 (landslide material) during the post processing. Hence I want to modify the interMixingFoam to assign diffusion coefficients in x,y, and z directions separately.
solver name has changed to interMixingFoam -> myInterMixingFoam
Then modified the createFields.H in like below.
//Modification made to defined the tensor term of the diffusion
dimensionedTensor Dcx23(mixture.lookup("Dcx23"));
dimensionedTensor Dcy23(mixture.lookup("Dcy23"));
dimensionedTensor Dcz23(mixture.lookup("Dcz23"));
At last I assigned the following terms to the alphaEqns.H
template<in-vector xDir, class tensor>
template<in-vector yDir, class tensor>
template<in-vector zDir, class tensor>
const tensor xDir = (1 0 0);
const tensor yDir = (0 1 0);
const tensor zDir = (0 0 1);
// Create the diffusion coefficients for alpha2<->alpha3
volTensorField Dcx23(Dx23*max(alpha3,scalar(0))*pos(alpha2));
volTensorField Dcx32(Dx23*max(alpha2,scalar(0))*pos(alpha3));
volTensorField Dcy23(Dy23*max(alpha3,scalar(0))*pos(alpha2));
volTensorField Dcy32(Dy23*max(alpha2,scalar(0))*pos(alpha3));
volTensorField Dcz23(Dz23*max(alpha3,scalar(0))*pos(alpha2));
volTensorField Dcz32(Dz23*max(alpha2,scalar(0))*pos(alpha3));
// add diffusive flux for alpha3->alpha2
alphaPhi2 -= fvc::interpolate(Dcx32)*mesh.magSf()*fvc::snGrad(( alpha1) & xDir); // x direction
alphaPhi2 -= fvc::interpolate(Dcy32)*mesh.magSf()*fvc::snGrad(( alpha1) & yDir); // y direction
alphaPhi2 -= fvc::interpolate(Dcz32)*mesh.magSf()*fvc::snGrad(( alpha1) & zDir); // z direction
// Solve for alpha2
// assigning of direction for the fvm would be either '& direction::x' or '& xDir'
fvScalarMatrix alpha2Eqn
fvm::ddt(alpha2)
+ fvc::div(alphaPhi2)
- fvm::laplacian((Dcx23 + Dcx32, alpha2) & xDir)
- fvm::laplacian((Dcy23 + Dcy32, alpha2) & yDir)
- fvm::laplacian((Dcv23 + Dcv32, alpha2) & zDir)
alpha2Eqn.solve();
But I unable to compile the code due to an error.
For your reference I attached the alphaEqns.H and createFields.H files to this link.
Your kind help is I highly appreciated.
Charitha_Dissanayaka is offline   Reply With Quote
openfoam
is it possible to define different mass diffusion coefficients in different zones? Weiqiang Liu Main CFD Forum 0 June 3, 2019 21:24
how to obtain mass diffusion coefficient with UDF? Weiqiang Liu FLUENT 0 May 28, 2019 13:32
Problem simulating the temperature rise in a composite material (chtMultiRegionFoam) Adam_K OpenFOAM Running, Solving & CFD 2 March 27, 2019 07:51
Harmonic average of Diffusion Tensors in Finite Volume Method Yurie_Breschnef Main CFD Forum 4 September 6, 2018 05:51
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
