Understanding flowRateOutletVelocity implementation
Old   August 16, 2024, 11:27
Default Understanding flowRateOutletVelocity implementation
David von Rüden
openFo is on a distinguished road
I am currently looking at the implementation of the flowRateOutletVelocity boundary condition (v2312) and don't understand why the calculation of the velocity based on the mass or volume flow is implemented the way it is. In the updateValues function they calculate the new velocity as follow:
const scalar flowRate = flowRate_->value(t);
    const scalar estimatedFlowRate = gSum(rho*(this->patch().magSf()*nUp));
    if (estimatedFlowRate > 0.5*flowRate)
        nUp *= (mag(flowRate)/mag(estimatedFlowRate));
    else
        nUp += ((flowRate - estimatedFlowRate)/gSum(rho*patch().magSf()));
    // Add the corrected normal component of velocity to the patch velocity
    Up += nUp*n;
I don't understand why the velocity can't just be calculated from the mass flow and set accordingly. Why is the estimated mass flow compared to 0.5*flowrate?
Does anyone have an idea?
Thanks in advance and kind regards
David
openFo is offline   Reply With Quote
Old   August 21, 2024, 03:22
David von Rüden
So I looked at the code for a little longer and now see that the two expressions for updating the velocity essentially come out to the same expression if you fully resolve them:
nUp_{new} = nUp_{old}* \frac{\dot{m}_{target}}{\dot{m}_{estimate}}
Also, I now see that the second equation will result in very large negative velocities in cases where the estimated flow rate is very large, whereas the first equation results in nUp = 0. Still, I don't understand the reason why
\dot{m}_{estimate} > 0.5 \dot{m}_{target}
is the criterion for switching.
boundaries condition, implementation, openfoam v2312
Radiation Models in General and the P1 implementation Tobi OpenFOAM Running, Solving & CFD 8 September 21, 2021 06:59
Issues in FGM combustion model implementation Lisandro Maders OpenFOAM Programming & Development 15 April 22, 2020 20:18
Understanding conjugate solver implementation in openfoam umeshisode OpenFOAM Programming & Development 0 February 9, 2015 07:17
Implementation issues of fvSchemes / laplacianScheme, in particular gaussLaplacianSch thomek OpenFOAM Programming & Development 0 October 18, 2010 06:10
Please explain the implementation of species transport Eqn in reactingFoam kallipygian OpenFOAM Running, Solving & CFD 0 October 13, 2008 08:29
