request for volVectorField U from objectRegistry region0 failed
Old   August 16, 2024, 10:22
Default request for volVectorField U from objectRegistry region0 failed
Deny
Chintan-21 is on a distinguished road
Hello, Good Morning to all
I am simulating multi-phase flow using the multiphaseEuler solver. I have setup all the files but I am getting the following error:
I tried to change the boundary condition but nothing happened.
Any help will greatly appreciated.
Thank you
--> FOAM FATAL ERROR:
available objects of type volVectorField are
9
DUDt.liquid
U.liquid_0
KdU.gas
U.gas_0
DUDt.gas
U.gas
Cc
U.liquid
KdU.liquid
Here is my U.gas file
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 11
\\/ M anipulation |
FoamFile
format ascii;
class volVectorField;
object U.gas;
//velocity of liquid phase
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0); //zero initial velocity in domain.
boundaryField
inlet
type zeroGradient;
outlet
type zeroGradient;
walls
type fixedValue;
value uniform (0 0 0);
U.liquid file
\\/ M anipulation |
FoamFile
format ascii;
object U.liquid;
boundaryField
inlet
type zeroGradient;
outlet
type zeroGradient;
walls
type fixedValue;
alpha.gas
\\/ M anipulation |
FoamFile
format ascii;
class volScalarField;
location "0";
object alpha.gas;
//volumetric fraction of gas
dimensions [0 0 0 0 0 0 0];
internalField uniform 0; //initiall zero gas in the domain
boundaryField
inlet
type fixedValue;
value uniform 0.14914;
outlet
type inletOutlet;
phi phi.gas;
inletValue uniform 1;
value uniform 1;
walls
type zeroGradient;
alpha.liquid
\\/ M anipulation |
FoamFile
format ascii;
location "0";
object alpha.liquid;
//volumetric fraction of liquid
internalField uniform 1; //domain is initially all liquid
boundaryField
inlet
type fixedValue;
value uniform 0.85086;
outlet
type inletOutlet;
phi phi.liquid;
inletValue uniform 0;
value uniform 0;
walls
type zeroGradient;
P file
\\/ M anipulation |
FoamFile
format ascii;
object p;
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 1.01e5; //set this to atmospheric. the inlet pressure will auto-regulate
boundaryField
inlet
type calculated;
value $internalField;
outlet
type calculated;
walls
type calculated;
p_rgh file
\\/ M anipulation |
FoamFile
format ascii;
object p_rgh;
boundaryField
inlet
type prghTotalPressure;
p0 uniform 1.15e5;
value uniform 1.15e5;
/* type fixedFluxPressure;*/
/* value $internalField;*/
outlet
type prghPressure;
p uniform 1e5;
value uniform 1e5;
walls
type zeroGradient;
fvSolution file
\\/ M anipulation |
FoamFile
format ascii;
class dictionary;
location "system";
object fvSolution;
solvers
"alpha.*"
nAlphaCorr 1;
nAlphaSubCycles 3; //3
p_rgh
solver PBiCGStab;
preconditioner DIC;
tolerance 1e-11; /// reduce to 10 original was 12
relTol 0.001;
p_rghFinal
$p_rgh;
relTol 0;
"U.*"
solver PBiCGStab;
preconditioner DILU;
tolerance 1e-12;
relTol 0;
"(e|h).*"
solver PBiCGStab;
tolerance 1e-12;
relTol 0;
"Yi.*"
solver PBiCGStab;
tolerance 1e-12;
relTol 0;
PIMPLE
nOuterCorrectors 5; //0 original was 5
nCorrectors 1;
nNonOrthogonalCorrectors 10; //0 original was 1
faceMomentum no;
VmDdtCorrection yes;
dragCorrection yes;
partialElimination no;
// changed below
outerCorrectorResidualControl
p_rgh
relTol 0;
tolerance 0.0001;
relaxationFactors
equations
".*" 0.9;
Thank you in advance.
Regards
Chintan
Chintan-21 is offline   Reply With Quote
Old   August 21, 2024, 09:14
Amirhossein Taran
amirhosseintaran is on a distinguished road
Hi Deny,
--> FOAM FATAL ERROR: request for volVectorField U from objectRegistry region0 failed
9
DUDt.liquid
U.liquid_0
KdU.gas
U.gas_0
DUDt.gas
U.gas
Cc
U.liquid
KdU.liquid
This error simply means that somewhere in the solution, you are requesting for U, whereas there is no object called U in your case. Apart from files in 0/ directory, can you tell me whats heppening in the code?
Did you add/change a library to look for an object called U?
Regards,
Amir.
amirhosseintaran is offline   Reply With Quote
Old   August 21, 2024, 14:48
Deny
Thank you Amir for your help.
But I haven't changed any library but I initialized my multi phase simulation using the incompressible solver and I am still getting the same error.
If you need the simulation file then I can upload it here.
Thank you for your help.!
Regards
Chintan
Old   August 22, 2024, 04:05
Yann
Yann will become famous soon enoughYann will become famous soon enough
Can you show your controlDict file? Don't you have a function object there requesting U?
Yann
Yann is offline   Reply With Quote
Old   August 22, 2024, 07:00
Amirhossein Taran
Regards
Chintan
Hi Chintan,
Yes that would be helpful to see whats happening. Also, what is multiphase simulation and what is incompressible solver? maybe that incompressible solver is requesting for U, and since it is a multiphase case, it couldnt find anything called U.
Reagrds,
Amir.
Old   August 22, 2024, 17:34
Deny
Hello Yann, Thank you for looking at my question! and helping me to solve problem.
I have checked my controlDict but I have no idea why I am getting the error.
for your reference I have pasted here my controlDict.
ControlDict
\\/ M anipulation |
FoamFile
format ascii;
class dictionary;
location "system";
object controlDict;
application foamRun;
solver multiphaseEuler;
startFrom startTime; //startTime;
startTime 0;
stopAt endTime;
endTime 10; // original was 10
deltaT 0.0000001; /// chaged original was 0.0000001
writeControl runTime;
writeInterval 0.001; // origianl was 0.001
purgeWrite 0;
writeFormat ascii;
writePrecision 10;
writeCompression off;
timeFormat general;
timePrecision 6;
runTimeModifiable yes;
adjustTimeStep yes;
maxCo 0.05; // original was 0.1
maxDeltaT 1;
functions
surfaceFieldValue1 //this one is for the outlet
type surfaceFieldValue;
libs ("libfieldFunctionObjects.so");
enabled yes;
writeControl timeStep;
writeInterval 100; //writes every 10 time steps. edit as necessary
log yes;
writeFields no;
regionType patch;
name outlet;
operation average;
weightField phi;
fields
U.liquid
U.gas
O2.gas
O2.liquid
N2.gas
N2.liquid
alpha.gas
alpha.liquid
surfaceFieldValue2 //this one is for the inlet
enabled yes;
log yes;
writeFields no;
regionType patch;
name inlet;
operation average;
weightField phi;
fields
U.liquid
U.gas
O2.gas
O2.liquid
N2.gas
N2.liquid
alpha.gas
alpha.liquid
Regards
Chintan
multi phase, multiphaseeulerfaom, objectregistry, volvectorfield
Paraview 5.10.1 - error - openfoam 11 - ubuntu 22.04 lts gu1 OpenFOAM Bugs 5 July 29, 2024 11:50
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel U.Golling OpenFOAM Running, Solving & CFD 52 September 23, 2023 04:35
[OpenFOAM] ParaView/Parafoam error when making animation Disco_Caine ParaView 6 September 28, 2010 10:54
user subroutine error CFDUSER CFX 2 December 9, 2006 07:31
user defined function cfduser CFX 0 April 29, 2006 11:58
