August 15, 2024, 09:10 |
granular pressure in multiphaseEulerFoam
Marat Mukhametzhanov
Hi foamers,
I've got a task to implement granular pressure inside of driftFluxFoam that I've already adjusted to model dry foams. Therefore I want to account for perpendicular pressure difference between adjacent gas bubbles (like in particle-liquid flow). I've checked in multiphaseEulerFoam for help, and it already has granular pressure dictionaries with radial distribution function. My question is this: where does multiphaseEulerFoam use or call this calculated granular pressure? I haven't found it in pEqn, UEqn, etc. It is implicit to my eyesight kinda.. Please share your ideas or materials where to look. In driftFluxFoam, for example, I have 3 equations: alphaEqn, pEqn, Ueqn(momentum). But this EulerFoam is much more complex. Thanks in advance! |
governing equations, granular bed, granular pressure, multiphaseeulerfoam |
viscosity udf don't use correct temperature and strain rate | rezvani | Fluent UDF and Scheme Programming | 8 | May 27, 2021 05:40 |
Fail to converge when solving with a fabricated solution | zizhou | FLUENT | 0 | March 22, 2021 06:33 |
Wind tunnel Boundary Conditions in Fluent | metmet | FLUENT | 6 | October 30, 2019 12:23 |
Getting divergence while increasing the back pressure at pressure outlet | greenfields15 | FLUENT | 0 | March 18, 2018 23:39 |
Periodic flow using Cyclic - comparison with Fluent | nusivares | OpenFOAM Running, Solving & CFD | 30 | December 12, 2017 05:35 |
