Error in Cluster (SLURM) while using openFoam |
July 18, 2024, 06:14 |
Shubham
Rep Power: 2 |
I am currently attempting to model a source term within a specific cell zone using OpenFOAM 11 and the fvModels option. The dynamic code compiles successfully on my local machine. However, due to the larger size of my case, I need to utilize the high-performance computing cluster available at my institute. On the cluster, I have successfully compiled the libraries and sources. Nonetheless, the simulation fails when I include the source term (fvModels). If I remove the source term, the simulation runs without issues. Below are the errors encountered when the source term is included: #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigSegv::sigHandler(int) at ??:? #2 ? in "/lib64/libc.so.6" #3 std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(std::string const&) in "/home/apps/compilers/gcc/7.5.0/lib64/libstdc++.so.6" #4 Foam::IOerrorLocation::IOerrorLocation(Foam::dicti onary const&) at ??:? #5 Foam::dictionary::lookupEntry(Foam::word const&, bool, bool) const at ??:? #6 Foam::dictionary::lookup(Foam::word const&, bool, bool) const at ??:? #7 Foam:olyCellSet::read(Foam::dictionary const&) at ??:? #8 Foam:olyCellSet:olyCellSet(Foam:olyMesh const&, Foam::dictionary const&) at ??:? #9 Foam::fvCellSet::fvCellSet(Foam::fvMesh const&, Foam::dictionary const&) at ??:? #10 Foam::fv::energySourceFvModelscalarSource::energyS ourceFvModelscalarSource(Foam::word const&, Foam::word const&, Foam::fvMesh const&, Foam::dictionary const&) at dynamicCode/energySource/codedFvModelTemplate.C:110 #11 Foam::fvModel::addRemovabledictionaryConstructorTo Table<Foam::fv::energySourceFvModelscalarSource>:: New(Foam::word const&, Foam::word const&, Foam::fvMesh const&, Foam::dictionary const&) at /home/apps/openfoam11/OpenFOAM-dev/src/OpenFOAM/lnInclude/autoPtrI.H:34 #12 Foam::fvModel::New(Foam::word const&, Foam::fvMesh const&, Foam::dictionary const&) at ??:? #13 Foam::fv::codedFvModel::redirectFvModel() const at ??:? #14 Foam::fv::codedFvModel::addSup(Foam::GeometricFiel d<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::fvMatrix<double>&) const at ??:? #15 Foam::tmp<Foam::fvMatrix<double> > Foam::fvModels::sourceTerm<double, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensionSet const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const at ??:? #16 Foam::solvers::fluid::thermophysicalPredictor() at ??:? #17 ? at ??:? #18 __libc_start_main in "/lib64/libc.so.6" #19 ? at ??:? /var/spool/slurmd/job68711/slurm_script: line 19: 237091 Segmentation fault foamRun I would greatly appreciate any insights or suggestions on how to resolve this issue. Thank you in advance. |
cluster computing, dynamic code, fvmodels, openfoam 11, source code |
[OpenFOAM.org] mpi shared library issue in Azure cluster & slurm | songyi719 | OpenFOAM Installation | 0 | July 25, 2023 03:13 |
[Other] OpenFOAM on a windows run cluster | jfournier | OpenFOAM Installation | 1 | August 20, 2016 17:07 |
[OpenFOAM.org] Installing OpenFOAM 2.1.0 on ROCKS cluster | aerospain | OpenFOAM Installation | 6 | December 15, 2014 03:35 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 06:55 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 06:25 |
