Updating a custom field using values from fvModels
Old   June 3, 2024, 10:50
Question Updating a custom field using values from fvModels
Marius
Muerio is on a distinguished road
Hello everyone,
I'm trying to update the values of a custom field I added to the multicomponentFluid solver in OpenFOAM 11.
The field should only depend on the values from a fvModel and shouldn't be affected by the flow itself.
Therefore I tried to extend the thermophysicalPredictor like this (copied from component fields Y_ and removed terms for transport):
void Foam::solvers::electrochemFluid::thermophysicalPredictor()
    tmp<fv::convectionScheme<scalar>> mvConvection(
        fv::convectionScheme<scalar>::New(mesh, fields, phi,
                                          mesh.schemes().div("div(phi,Yi_h)")));
    reaction->correct();
    volScalarField &myField = myField_;
    fvScalarMatrix myFieldEqn(fvm::ddt(myField) == fvModels().source(myField));
    myFieldEqn.relax();
    fvConstraints().constrain(myFieldEqn);
    myFieldEqn.solve("myField");
    fvConstraints().constrain(myField);
    forAll(Y, i)
For testing purposes I use a simple fvModel that assigns the value of 1.0 to all cells:
forAll(cells, i){eqn.source()[cells[i]] = 1.0;}
All boundaries are defined as zeroGradient:
internalField   uniform 0;
boundaryField
        type            zeroGradient;
It compiles and starts without issue, but once it reaches the "myFieldEqn.solve" line, the solver crashes with an Arithmetic exception in Foam::divide. I guess it divides by 0 while trying to solve?!
Is there something obvious I missed?
What could I try to resolve this issue?
Thank you in advance for any help!
Muerio is offline   Reply With Quote
arithmetic exception, custom field, fvmodel, fvmodels
Create non-uniform internal field values based on a graph or table finn_amann OpenFOAM Pre-Processing 0 June 28, 2023 09:20
getting cutplanes of a custom vector field (vorticity in my case) zog OpenFOAM Post-Processing 0 February 2, 2023 19:26
Can i take contours from Custom field function i defined ? rahulohlan FLUENT 3 April 18, 2017 14:39
Store data in a different field from a custom BC cstuart OpenFOAM Programming & Development 0 March 21, 2017 11:14
Setting patch field values equal to internal field values leroyv OpenFOAM Programming & Development 1 October 21, 2014 16:49
