Empirical equations in OpenFOAM
Old   May 14, 2024, 03:34
Default Empirical equations in OpenFOAM
Sagar
Dave110 is on a distinguished road
Hello Foamers,
I want to add temperature dependent empirical formula in my solver calculation.
For example:
1) p = a + b*T+ c*T^2
2) p = A*exp(B/T)
where p and T both are volScalarField having dimensions of pressure and temperature respectively.
And a, b, c, A, B are constant values.
I know both are empirical formula and dimensionally imbalance on LHS and RHS.
To handle this type of equation, I have come across one method by giving dimensions to a,b,c,A,B using dimensionedScalar.
Is there any other-way to handle these type of equations in OpenFOAM?
Dave110 is offline   Reply With Quote
Old   May 14, 2024, 12:20
Tobermory will become famous soon enough
I doubt it. When adding terms, they must clearly have the same dimensions, otherwise it is not physical. You could try making T dimensionless, but I would just perservere with setting the correct dimensions for the coefficients. The dimension checking is a good error trap for your coding.
Tobermory is offline   Reply With Quote
empirical equations, openfoam, temperature dependent
Energy equations in OpenFoam Bloerb OpenFOAM Running, Solving & CFD 9 July 1, 2024 14:22
OPENFOAM for Aeroacoustics simulations (using Linearized Euler Equations) ms518 OpenFOAM 6 February 21, 2021 17:49
OpenFOAM 4.0 Released CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 2 October 6, 2017 06:40
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin CFDFoundation OpenFOAM Announcements from Other Sources 0 January 4, 2017 07:15
UNIGE February 13th-17th - 2107. OpenFOAM advaced training days joegi.geo OpenFOAM Announcements from Other Sources 0 October 1, 2016 20:20
