Adding surface tension force to Lagrangian particle forces |
May 10, 2024, 05:03 |
Vivekananda
Rep Power: 9 |
Hello all,
I am trying to add the surface tension force calculated in src/transportmodels/interfacialProperties/interfaceProperties.C in the particle forces to the lagrangian library. My objective is to see the effect of surface tension on particle. Since the surface tension force is already implemented in OF, it would be wiser to add the force from interfaceProperties to the lagrangian particle force directory. However, although I have compiled different forces, but those are the variation of pre-compied forces in the lagrangian library. I have never merged two different libraries. e.g src/transportmodels/interfacialProperties/interfaceProperties.C to the particle force library. If anyone can help me in doing this, or give me some expamples, it would be much apprecited. Regards Viveks |
eulerian-lagrangian, library compilation, particle forces, surfacetension |
chtmultiRegion case is not generating sets folder in postprocessing | boffin5 | OpenFOAM Running, Solving & CFD | 14 | April 19, 2024 18:40 |
Lagrangian particle tracking in mechanically agitated mono-dispersed and poly-dispers | anandjjadhaviitr | ANSYS | 0 | September 18, 2020 16:19 |
OpenFOAM error | Vinay Kumar V | Main CFD Forum | 0 | February 20, 2020 10:17 |
Surface tension - Continuum Surface Force model | Robert | Main CFD Forum | 0 | May 2, 2002 08:34 |
surface tension force | Ray | Main CFD Forum | 0 | October 17, 2001 16:42 |
