Trouble adding temperature equations to icoFoam
Old   April 21, 2024, 00:46
Default Trouble adding temperature equations to icoFoam
srikanth
alpha_13 is on a distinguished road
Hi ,
I was trying to make a new solver "icoTempFoam" by adding three dimensional heat conduction equation (Fourier-biot equation) to icoFoam and the temperature field by using this openFoamwiki page :
https://openfoamwiki.net/index.php/H...ure_to_icoFoam
I am using openFoamv9 , because i had trouble doing the same on openFoamv11 and one of my friends got it right and he was using openFoamv9 , so i switched to it but now in openFoamv9 i'm getting new errors when i run the 'wmake ' command:
make: *** No rule to make target 'Make/linux64GccDPInt32Opt/icoTempFoam.C.dep', needed by 'Make/linux64GccDPInt32Opt/icoTempFoam.o'. Stop.
Thanks a lot for your replies 😊
alpha_13 is offline   Reply With Quote
Old   April 22, 2024, 05:23
Lorenzo
Lorenzo210 is on a distinguished road
Hi Srikanth,
I guess that the main file (the only file .C inside the solver folder) is not named correctly, it should be icoTempFoam.C, please check it.
If it is called like that, then I would check the document "files" inside Make folder.
Here, it should be written:
icoTempFoam.C
EXE = $(FOAM_USER_APPBIN)/icoTempFoam
Best regards,
Lorenzo
Lorenzo210 is offline   Reply With Quote
Old   April 22, 2024, 12:40
Default Thanks , it worked !
srikanth
Thank you so much it worked !
renaming the file name to icoTempFoam.C fixed the issue
heat transfer, icofoam solver error
[ImmersedBoundary] Adding force term to Navier.S equaion(Implementing ImmersedBoundaryMethod to icoFoam) Daniel73 OpenFOAM Community Contributions 5 June 18, 2016 13:48
chtMultiRegionSimpleFoam samiam1000 OpenFOAM Running, Solving & CFD 39 March 31, 2016 09:43
Problems adding temperature to icoFoam sur4j OpenFOAM Programming & Development 8 January 11, 2015 02:14
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
wmake error while adding T to icoFoam boongsin12 OpenFOAM 11 November 23, 2012 20:34
