Issue while reading labelList cells_ of cellSetOption |
Marķa Rosales
Rep Power: 3 ![]() |
Good day,
I wanted to implement some new features to actuationdisksource in Openfoam ESI 2012 and 2306 versions. I wanted to check if the scalar T computed was of the same value that the total amount applied in Usource[celli], so I added some new line codes to verify if there was a balance. I checked it by adding to each method (Froude and variableScaling) something like: Code:
// (BJSB:Eq. 3.9) const scalar a = 1.0 - Cp/Ct; const scalar T = 2.0*rhoRef*diskArea_*magSqr(Uref & diskDir_)*a*(1 - a); scalar magSource = 0.0; scalar cellInCellSet = 0.0; scalar volumenCheck = 0.0; for (const label celli : cells_) { Usource[celli] += ((cellsV[celli]/V())*T)*diskDir_; magSource += mag(Usource[celli] & diskDir_); cellInCellSet += 1.0; volumenCheck += (cellsV[celli]/V()); } /* DEBUG PART IV*/ Info << "the variable cells_ is = " << cells() << endl; Info << "Volumen check via (cellsV[celli]/V()) " << volumenCheck << endl; Info << "Volumen check via V() " << V() << endl; Info << "Total cells check via cellInCellSet " << cellInCellSet << endl; Info << "Total thrust " << T << endl; Info << "Total Usource " << magSource << endl; By running turbineSiting tutorial of ESI2306, the cellSets are of 484 cells but the counter 'cellInCellSet ' inside the for-loop finds 374, that is the same value seen when printing on screen cells(), that at the end is a ratio of 0.77 seen in volumenCheck. This also ends that magSource does not match with T What could be the reason that original fvOption is not receiving the full list of cells selected in the cellZone/cellSet? Or are there issues in my line codes? |
Marķa Rosales
I'd say, issue solved! by adding this, magic happens:
reduce(magSource, sumOp<scalar>()); A new thing learned |
actuationdisk, actuationdisksource, cellsets, fvoptions, programming |
[snappyHexMesh] snappyHexMesh sticking point | natty_king | OpenFOAM Meshing & Mesh Conversion | 11 | February 20, 2024 09:12 |
Averaging over iterations for steady-state simulation | CFD student | Fluent UDF and Scheme Programming | 8 | September 22, 2022 03:39 |
Postprocess: sampleDict works but creates no output folder | shock77 | OpenFOAM Post-Processing | 14 | November 15, 2021 08:27 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
