Writing and viewing Lagrangian data in openFoam and Paraview |
March 16, 2024, 07:26 |
Divyaprakash
Rep Power: 12 |
I have a set of points that represent a structure whose deformations are solved for at every time step. I am storing those points as follows.
std::vector<double> pposx, pposy, pposz; |
March 16, 2024, 07:33 |
Mark Olesen
Rep Power: 40 |
Note that "paraFoam" is a shell script, not a program. If you wish to visualize x/y/z values in paraview, you'll need to see what type of import possibilities are available. Either use your values to generate a CSV file and import that, or generate a VTK file yourself. The legacy VTK format is dead easy, but you might do okay with OBJ format too. Take a look at the coordSetWriters in OpenFOAM for inspiration.
lagrangian, parafoam |
[blockMesh] viewing mesh in paraview | tenichols19 | OpenFOAM Meshing & Mesh Conversion | 0 | October 2, 2019 08:55 |
