Setting up The specific pressure (Incompressible Case) |
January 5, 2024, 06:25 |
Chandra Napitupulu
Rep Power: 2 |
I'm struggling to run the simulation of the underwater object. I have set up the initial field of pressure 2 MPa (At depth 200m). When I've run it by pimpleFoam as Solver, at the first iteration, the pressure of object is going to start at 3000-10000 Pa. It should be started 2 MPa and increased so forth. What kind the boundary type for my STL Object?
January 5, 2024, 06:31 |
#2 | |
ONESP-RO
Rep Power: 5 |
I think your question is not clear, could you please provide more details? In OpenFOAM, the incompressible solvers use kinematic pressure which is the static pressure divided by density.
Don't keep making the same mistakes. Try to make new mistakes. |
January 5, 2024, 07:09 |
#3 | |
Chandra Napitupulu
Rep Power: 2 |
Dear NotOverUnderated, Sorry for the confused question. I want the pressure object is followed by the initial field pressure (correct me if i'm wrong). According to your explanation, I thought that the pressure in incompressible, it is Hydrostatic pressure. |
incompressible, openfoam, pressure, underwater |
reverse flow in centrifugal fan blades | kalm | CFX | 20 | December 2, 2023 06:25 |
Continuity Equation for multicomponent simulation | lordluan | CFX | 15 | May 19, 2020 18:36 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
