Is SRF library applicable to multiphase simulation?
Old   December 17, 2023, 10:01
Question Is SRF library applicable to multiphase simulation?
Hamed Hoorijani
Hamedhoorijani is on a distinguished road
Hi everyone,
I'm wondering if the SRF library is applicable to a multiphase case. I have a cylindrical geometry with rotational movement along its center axis, as shown in the attached figure. The red face in the figure represents the inlet, where gas is injected into the domain from the curved wall.
I've attempted to use rotatingPressureInletOutletVelocity for the gas velocity boundary condition at the inlet, but I want to model the geometry rotation as well. I want to model this using the two-fluid model (gas-solid), specifically with the multiphaseEulerFOAM solver in OpenFOAM 8.
I appreciate any suggestions and guidance for modeling this case.
Kind regards,
Hamed
Hamedhoorijani is offline   Reply With Quote
Old   February 12, 2024, 14:41
ASR
sr786 is on a distinguished road
SRF is specific to SRFSimpleFoam and SRFPimpleFoam which are single phase. MRF can be used for any solver, single or multiphase. With MRF you can set it up as SRF by defining stationary and moving walls similar to how you'd do it in a commerical code like FLUENT
sr786 is offline   Reply With Quote
boundary condition, openfoam 8, rotation cylinder
Courant number in multiphase flow simulation Ahyar Main CFD Forum 1 March 18, 2022 10:00
Multiphase heat exchange simulation efer2109 STAR-CCM+ 1 September 15, 2016 14:22
about Lagrangian Multiphase Simulation jhlee9622 STAR-CCM+ 0 March 18, 2015 02:38
Which turbulence model is applicable for Plain diffuser flow simulation in openFOAM? mukut OpenFOAM Running, Solving & CFD 4 January 30, 2015 09:06
Need help in Multiphase simulation leonlo1984 FLUENT 0 January 16, 2011 11:28
