Error "Unknown null-constructable patchField type kqRWallFunction for patch cyclone "
Old   December 8, 2023, 06:59
Question Error "Unknown null-constructable patchField type kqRWallFunction for patch cyclone "
Ishak
Ishak.Mazing is on a distinguished road
Hello Everyone,
I'm trying to update a PANS turbulent model that I compiled back then in OpenFoam v7 but now with the new version of OpenFoam v11 I was obliged to change some new command..
Whatever, I correct and update the code with the new command and it compiled as well.
but when I try to launch a simulation I got this error :
--> FOAM FATAL ERROR:
Unknown null-constructable patchField type kqRWallFunction for patch cyclone of type wall for field kU
Valid null-constructable patchField types are :
24
calculated
cyclic
cyclicSlip
empty
extrapolatedCalculated
fixedEnergy
fixedUnburntEnthalpy
fixedValue
gradientEnergy
gradientUnburntEnthalpy
internal
mixedEnergy
mixedUnburntEnthalpy
nonConformalCyclic
nonConformalError
nonConformalProcessorCyclic
processor
processorCyclic
slip
symmetry
symmetryPlane
wedge
zeroGradient
zeroInletOutlet
    From function static Foam::tmp<Foam::fvPatchField<Type> > Foam::fvPatchField<Type>::New(const Foam::word&, const Foam::word&, const Foam::fvPatch&, const Foam::DimensionedField<Type, Foam::volMesh>&) [with Type = double]
    in file lnInclude/fvPatchFieldNew.C at line 51.
FOAM aborting
I check the specifed wall (cyclone) and thier was a wall function : kqRWallFunction. I tried to delete the kU file, same problem. The simulation works only when I change the wall function in the "k" file ..
The turbulence model called PANS and here's somme of the added constructor :
    fEpsilon_
        dimensioned<scalar>::lookupOrAddToDict
            "fEpsilon",
            this->coeffDict_,
            1.0
    uLim_
            "fKupperLimit",
            this->coeffDict_,
            1.0
    loLim_
            "fKlowerLimit",
            this->coeffDict_,
            0.1
    fK_
        IOobject
            this->groupName("fK"),
            this->runTime_.name(),
            this->mesh_,
            IOobject::NO_READ,
            IOobject::AUTO_WRITE
        this->mesh_,
        dimensionedScalar("zero",loLim_)
    C2U
        IOobject
            "C2U",
            this->runTime_.timeName(),
            this->mesh_
        C1_ + (fK_/fEpsilon_)*(C2_ - C1_)
    delta_
        LESdelta::New
            IOobject::groupName("delta", U.group()),
            *this,
            this->coeffDict_
    k_
        IOobject
            this->groupName("k"),
            this->mesh_,
            IOobject::MUST_READ,
        this->mesh_
    kU_
        IOobject
            this->groupName("kU"),
            this->mesh_,
            IOobject::NO_READ,
        //this->mesh_,
        k_*fK_,
        k_.boundaryField().types()
    epsilon_
        IOobject
            this->groupName("epsilon"),
            this->mesh_,
        this->mesh_
    epsilonU_
        IOobject
            this->groupName("epsilonU"),
            this->mesh_,
            IOobject::NO_READ,
        //this->mesh_
        epsilon_*fEpsilon_,
        epsilon_.boundaryField().types()
Can you help please ?
Ishak.Mazing is offline   Reply With Quote
Old   December 8, 2023, 08:30
Domenico Lahaye
dlahaye is on a distinguished road
Should patch be of type wall allowing wall bc to be applied?
dlahaye is offline   Reply With Quote
Old   July 2, 2024, 09:59
Ishak
I fixed the problem.
I figured how to configure the PANS turbulence model in OF v 11, otherwise here's the code.
The code worked well for me, but as I'm new in OF don't hesitate to correct me if I'm wrong please.
C file:
#include "kEpsilonPANS.H"
#include "fvModels.H"
#include "fvConstraints.H"
#include "bound.H"
namespace Foam
namespace RASModels
// * * * * * * * * * * * * Protected Member Functions  * * * * * * * * * * * //
template<class BasicMomentumTransportModel>
void kEpsilonPANS<BasicMomentumTransportModel>::correctNut()
    this->nut_ = Cmu_*sqr(kU_)/epsilonU_;
    this->nut_.correctBoundaryConditions();
    fvConstraints::New(this->mesh_).constrain(this->nut_);
tmp<fvScalarMatrix> kEpsilonPANS<BasicMomentumTransportModel>::kSource() const
    return tmp<fvScalarMatrix>
        new fvScalarMatrix
            kU_,
            dimVolume*this->rho_.dimensions()*kU_.dimensions()
            /dimTime
tmp<fvScalarMatrix> kEpsilonPANS<BasicMomentumTransportModel>::epsilonSource() const
        new fvScalarMatrix
            epsilonU_,
            dimVolume*this->rho_.dimensions()*epsilonU_.dimensions()
            /dimTime
// * * * * * * * * * * * * * * * * Constructors  * * * * * * * * * * * * * * //
kEpsilonPANS<BasicMomentumTransportModel>::kEpsilonPANS
    const alphaField& alpha,
    const rhoField& rho,
    const volVectorField& U,
    const surfaceScalarField& alphaRhoPhi,
    const surfaceScalarField& phi,
    const viscosity& viscosity,
    const word& type
    eddyViscosity<RASModel<BasicMomentumTransportModel>>
        type,
        alpha,
        rho,
        U,
        alphaRhoPhi,
        phi,
        viscosity
    Cmu_
            "Cmu",
            this->coeffDict_,
            0.09
    C1_
            "C1",
            this->coeffDict_,
            1.44
    C2_
            "C2",
            this->coeffDict_,
            1.92
    C3_
            "C3",
            this->coeffDict_,
            -0.33
    sigmak_
            "sigmak",
            this->coeffDict_,
            1.0
    sigmaEps_
            "sigmaEps",
            this->coeffDict_,
            1.3
    fEpsilon_
            "fEpsilon",
            this->coeffDict_,
            1.0
    uLim_
            "fKupperLimit",
            this->coeffDict_,
            1.0
    loLim_
            "fKlowerLimit",
            this->coeffDict_,
            0.1
    fK_
        IOobject
            this->mesh_,
            IOobject::NO_READ,
        this->mesh_,
    C2U
        IOobject
            "C2U",
            this->mesh_
    delta_
        LESdelta::New
            *this,
            this->coeffDict_
    k_
        IOobject
            this->mesh_,
        this->mesh_
    epsilon_
        IOobject
            this->mesh_,
        this->mesh_
    kU_
        IOobject
            this->mesh_,
            IOobject::READ_IF_PRESENT,
        //this->mesh_
        this->k_*this->fK_
        //this->k_.boundaryField().types()
    epsilonU_
        IOobject
            this->mesh_,
        //this->mesh_
        this->epsilon_*this->fEpsilon_
        //this->epsilon_.boundaryField().types()
    bound(k_, this->kMin_);
    bound(epsilon_, this->epsilonMin_);
    bound(kU_, min(fK_)*this->kMin_);
    bound(epsilonU_, fEpsilon_*this->epsilonMin_);
    if (type == typeName)
        this->printCoeffs(type);
        correctNut();
// * * * * * * * * * * * * * * * Member Functions  * * * * * * * * * * * * * //
bool kEpsilonPANS<BasicMomentumTransportModel>::read()
    if (eddyViscosity<RASModel<BasicMomentumTransportModel>>::read())
        Cmu_.readIfPresent(this->coeffDict());
        C1_.readIfPresent(this->coeffDict());
        C2_.readIfPresent(this->coeffDict());
        C3_.readIfPresent(this->coeffDict());
        sigmak_.readIfPresent(this->coeffDict());
        sigmaEps_.readIfPresent(this->coeffDict());
        fEpsilon_.readIfPresent(this->coeffDict());
        uLim_.readIfPresent(this->coeffDict());
        loLim_.readIfPresent(this->coeffDict());
        return true;
    else
        return false;
void kEpsilonPANS<BasicMomentumTransportModel>::correct()
    if (!this->turbulence_)
        return;
    // Local references
    const alphaField& alpha = this->alpha_;
    const rhoField& rho = this->rho_;
    const surfaceScalarField& alphaRhoPhi = this->alphaRhoPhi_;
    const volVectorField& U = this->U_;
    volScalarField& nut = this->nut_;
    const Foam::fvModels& fvModels(Foam::fvModels::New(this->mesh_));
    const Foam::fvConstraints& fvConstraints
        Foam::fvConstraints::New(this->mesh_)
    eddyViscosity<RASModel<BasicMomentumTransportModel>>::correct();
    volScalarField::Internal divU
        fvc::div(fvc::absolute(this->phi(), U))().v()
    tmp<volTensorField> tgradU = fvc::grad(U);
    volScalarField::Internal G
        this->GName(),
        nut.v()*(dev(twoSymm(tgradU().v())) && tgradU().v())
    tgradU.clear();
    // Update epsilon and G at the wall
    epsilonU_.boundaryFieldRef().updateCoeffs();
    // Dissipation equation
    tmp<fvScalarMatrix> epsUEqn
        fvm::ddt(alpha, rho, epsilonU_)
      + fvm::div(alphaRhoPhi, epsilonU_)
      - fvm::laplacian(alpha*rho*DepsilonUEff(), epsilonU_)
        C1_*alpha()*rho()*G*epsilonU_()/kU_()
      - fvm::SuSp(((2.0/3.0)*C1_ + C3_)*alpha()*rho()*divU, epsilonU_)
      - fvm::Sp(C2U*alpha()*rho()*epsilonU_()/kU_(), epsilonU_)
      + epsilonSource()
      + fvModels.source(alpha, rho, epsilonU_)
    epsUEqn.ref().relax();
    fvConstraints.constrain(epsUEqn.ref());
    epsUEqn.ref().boundaryManipulate(epsilonU_.boundaryFieldRef());
    solve(epsUEqn);
    fvConstraints.constrain(epsilonU_);
    // Turbulent kinetic energy equation
    tmp<fvScalarMatrix> kUEqn
        fvm::ddt(alpha, rho, kU_)
      + fvm::div(alphaRhoPhi, kU_)
      - fvm::laplacian(alpha*rho*DkUEff(), kU_)
        alpha()*rho()*G
      - fvm::SuSp((2.0/3.0)*alpha()*rho()*divU, kU_)
      - fvm::Sp(alpha()*rho()*epsilonU_()/kU_(), kU_)
      + kSource()
      + fvModels.source(alpha, rho, kU_)
    kUEqn.ref().relax();
    fvConstraints.constrain(kUEqn.ref());
    solve(kUEqn);
    fvConstraints.constrain(kU_);
    // Calculation of Turbulent kinetic energy and Dissipation rate
    k_ = kU_/fK_;
    k_.correctBoundaryConditions();
    epsilon_ = epsilonU_/fEpsilon_;
    epsilon_.correctBoundaryConditions();
    correctNut();
    // Recalculate fK and C2U with new kU and epsilonU
    // Calculate the turbulence integral length scale
    volScalarField::Internal Lambda
    	pow(k_,1.5)/epsilon_
    // update fK
    fK_.primitiveFieldRef() = min(max(
    	sqrt(Cmu_.value())*pow(delta()/Lambda,2.0/3.0), loLim_), uLim_);
    // update C2U
    C2U = C1_ + (fK_/fEpsilon_)*(C2_ - C1_);
} // End namespace RASModels
} // End namespace Foam
and the H file :
Description
    PANS implementation based on the Standard k-epsilon turbulence model for
    incompressible and compressible flows including rapid distortion theory
    (RDT) based compression term. The fK parameter, responsible for switching
    from RAS to DNS is calculated based on [Girimaji,2005]:
    fK_ = min( max( sqrt(Cmu_.value())*(pow(delta()/
           (pow(kU_,1.5)/epsilonU_),2.0/3.0)) , loLimVec ), uLimVec );
    bounded between loLim (DNS -> 0.0) and uLim (RAS -> 1.0). The lower the
    uLim, defined in turbulenceProperties dict, more scales are resolved.
    Reference:
    \verbatim
        Standard model:
            Launder, B. E., & Spalding, D. B. (1972).
            Lectures in mathematical models of turbulence.
            Launder, B. E., & Spalding, D. B. (1974).
            The numerical computation of turbulent flows.
            Computer methods in applied mechanics and engineering,
            3(2), 269-289.
        For the RDT-based compression term:
            El Tahry, S. H. (1983).
            k-epsilon equation for compressible reciprocating engine flows.
            Journal of Energy, 7(4), 345-353.
        PANS:
            Girimaji, S. S. & Abdol-Hamid K. S. (2005).
            Partially-averaged Navier-Stokes model for turbulence:
            Implementation and Validation.
            43rd AIAA Aerospace Science Meeting and Exhibit.
            Girimaji, S. S. (2006).
            Partially-averaged Navier-Stokes method for turbulence: A Reynolds
            averaged Navier-Stokes to direct numerical simulation bridging
            method.
            Journal of Applied Mechanics, Vol 73, 413-421.
            Girimaji, S. & Jeong, E. & Srinivasan, R. (2006).
            Partially-averaged Navier-Stokes method for turbulence: Fixed point
            analysis and comparison with unsteady partially averaged
            Navier-Stokes.
            Journal of Applied Mechanics, Vol 73, 422-429.
    \endverbatim
    The default model coefficients are
    \verbatim
        kEpsilonPANSCoeffs
            Cmu         0.09;
            C1          1.44;
            C2          1.92;
            C3          -0.33;
            sigmak      1.0;
            sigmaEps    1.3;
            fEpsilon    1.0;
            fKupperLimit  1.0;
            fKlowerLimit  0.1;
            // Delta must be specified for PANS e.g.
            delta cubeRootVol;
            cubeRootVolCoeffs
    \endverbatim
SourceFiles
    kEpsilonPANS.C
#ifndef kEpsilonPANS_H
#define kEpsilonPANS_H
#include "RASModel.H"
#include "eddyViscosity.H"
#include "LESdelta.H"
namespace Foam
namespace RASModels
                          Class kEpsilon Declaration
class kEpsilonPANS
    public eddyViscosity<RASModel<BasicMomentumTransportModel>>
    // Private Member Functions
       /* // Disallow default bitwise copy construct and assignment
        kEpsilonPANS(const kEpsilonPANS&);
        kEpsilonPANS& operator=(const kEpsilonPANS&);
protected:
    // Protected data
        // Model coefficients
            dimensionedScalar Cmu_;
            dimensionedScalar C1_;
            dimensionedScalar C2_;
            dimensionedScalar C3_;
            dimensionedScalar sigmak_;
            dimensionedScalar sigmaEps_;
            dimensionedScalar fEpsilon_;
            dimensionedScalar uLim_;
            dimensionedScalar loLim_;
        // Fields
            volScalarField fK_;
            volScalarField C2U;
            //- Run-time selectable delta model
            autoPtr<Foam::LESdelta> delta_;
            volScalarField k_;
            volScalarField epsilon_;
            volScalarField kU_;
            volScalarField epsilonU_;
    // Protected Member Functions
        virtual void correctNut();
        virtual tmp<fvScalarMatrix> kSource() const;
        virtual tmp<fvScalarMatrix> epsilonSource() const;
public:
    typedef typename BasicMomentumTransportModel::alphaField alphaField;
    typedef typename BasicMomentumTransportModel::rhoField rhoField;
    //- Runtime type information
    TypeName("kEpsilonPANS");
    // Constructors
        //- Construct from components
        kEpsilonPANS
            const word& type = typeName
        //- Disallow default bitwise copy construction
        kEpsilonPANS(const kEpsilonPANS&) = delete;
    //- Destructor
    virtual ~kEpsilonPANS()
    // Member Functions
        //- Re-read model coefficients if they have changed
        virtual bool read();
        //- Access function to filter width
        inline const volScalarField& delta() const
            return delta_();
        //- Return the effective diffusivity for unresolved k
        tmp<volScalarField> DkUEff() const
            return volScalarField::New
                "DkUEff",
                (this->nut_/(fK_*fK_*sigmak_/fEpsilon_)
                + this->nu())
        //- Return the effective diffusivity for unresolved epsilon
        tmp<volScalarField> DepsilonUEff() const
            return tmp<volScalarField>
                new volScalarField
                    "DepsilonUEff",
                    (this->nut_/(fK_*fK_*sigmaEps_/fEpsilon_)
                     + this->nu())
        //- Return the turbulence specific dissipation rate
        virtual tmp<volScalarField> omega() const
                "omega",
                epsilon_/(Cmu_*k_)
        //- Return the turbulence kinetic energy
        virtual tmp<volScalarField> k() const
            return k_;
        //- Return the turbulence kinetic energy dissipation rate
        virtual tmp<volScalarField> epsilon() const
            return epsilon_;
        //- Return the unresolved turbulence kinetic energy
        virtual tmp<volScalarField> kU() const
            return kU_;
        //- Return the unresolved turbulence kinetic energy dissipation rate
        virtual tmp<volScalarField> epsilonU() const
            return epsilonU_;
        //- Solve the turbulence equations and correct the turbulence viscosity
        virtual void correct();
    // Member Operators
        //- Disallow default bitwise assignment
        void operator=(const kEpsilonPANS&) = delete;
#ifdef NoRepository
    #include "kEpsilonPANS.C"
#endif
#endif
c++ code, openfoam 11, turbulence free
convergence problem of steady 2D film cooling calculation using chtMultiRegionFoam ruanyg968tf OpenFOAM Running, Solving & CFD 1 April 10, 2024 03:23
[Commercial meshers] Problem with Mesh conversion from FLUENT Meshing to OpenFOAM mn17jyf OpenFOAM Meshing & Mesh Conversion 3 November 1, 2023 10:49
Instability in buoyantSimpleFoam Avandri OpenFOAM Running, Solving & CFD 0 August 7, 2020 17:13
Pressure instability with rhoSimpleFoam daniel_mills OpenFOAM Running, Solving & CFD 44 February 17, 2011 18:08
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
