Applying a retarding shear in a row of cells for incompressible flows
Old   November 20, 2023, 04:56
Default Applying a retarding shear in a row of cells for incompressible flows
Marķa Rosales
MMRC is on a distinguished road
Hello community,
Can you please give me your opinion in this implementation of 'retarding shear stress' proposed by Richard & Hoxey (1993) in the row of cells adyacent to wall that helps to minimize the over production of TKE and so the peak of TKE when plotting against vertical profile: shear = rho * (u_friction)²
I'm running simpleFoam, must I remove or keep rho (density) in the calculation of the source?
By using topoSetDict we can catch the first row of cells adyacent to ground patch (wall): first patchToFace and then setToCellZone.
Then, by using fvOptions codedVectorSource:
PHP Code:
retardingShear{    type            vectorCodedSource;    selectionMode   cellZone;    cellZone        areaSet;  // name of my cellZone    fields          (U);    writeToFile     true;    name            retardingShear;        codeCorrect        #{        #};    codeConstrain    #{    #};        codeInclude        #{        #};    codeAddSup            #{                vectorField& retardingShear = eqn.source();  // will asign calculation to source side of fvMatrix         vector Ufriction (-0.57 0 0); // is the friction velocity near wall         vector diskRetardingShear (-1 0 0); // is the direction opposite to normal wind flow                const labelList& cellIDs = cells();                forAll(cellIDs, i)                {                    label cellI = cellIDs[i];                            retardingShear[cellI] += mag(Ufriction)*diskRetardingShear; // the left side with += is thought to be 'a sink', AND the right side is the value of shear with its current direction                }}
Is it good practice to combine '+=' (sink assigment) with the current direction of this retarding shear ?
I've seen that some user multiplies the sources term by cell volumes, when is this needed?
I apologize but I lost the original code and this code is what I remember that I could run.
Any ideas are welcome
MMRC is offline   Reply With Quote
Old   November 22, 2023, 11:28
Marķa Rosales
Hello community,
Here is my code, in fact, it helped to lower the effect of over production of TKE
codedSource
selectionMode cellSet;
cellSet groundCellSet;
fields (U);
name retardingshear;
codeInclude
codeCorrect
codeAddSup
vectorField& Usource = eqn.source();
const scalarField& V = mesh_.V();
vector dir(-1,0,0);
// Apply the source
forAll(V, i)
// cell volume specific source
Usource[i] -= (0.1*V[i])*dir;
codeConstrain
The value I used was thinking that I should have input of it without density , because I'll be using density. The use of volume of the cell is something that I copy someone used for their sources on other fields, maybe this is not correct.
Please share your comments, this supposed to be a 'retarding shear stress' applied to the cell adjacent to ground patch
fvoption, shear stress, sources
Calculating source term total cell-zone volume parallel computation RobV Fluent UDF and Scheme Programming 2 May 30, 2022 04:46
[snappyHexMesh] snappyHexMesh does not detect highly skewed faces? ptpacheco OpenFOAM Meshing & Mesh Conversion 1 January 4, 2022 13:37
cellZone not taking all the cells inside rahulksoni OpenFOAM Running, Solving & CFD 6 January 25, 2019 01:11
cellZone not taking all the cells inside rahulksoni OpenFOAM 0 January 16, 2019 02:16
shear force applying Danial1992 FLUENT 0 May 23, 2017 04:19
