Compiling and using new turbulence model in OF 5 |
November 17, 2023, 07:00 |
#1 | ||
Hamed Hoorijani
Rep Power: 7 |
I want to use a set of turbulence models that were used by a previous student in our lab. I placed the models in the $FOAM_USER_PROJECT_DIR directory and managed to compile them without any errors or warnings. I attempted to test these turbulence models using the pimpleFOAM solver with the pitzDaily tutorial case. However, I encountered the error below, and I'm having difficulty understanding its reason. I also tried using these models with compressible solvers, rhoPimpleFOAM (I made the necessary changes during the compilation step), but I obtained the same results. pimpleFOAM: Quote:
rhoPimpleFOAM: Quote:
I would greatly appreciate any hints or guidance. Best regards |
November 17, 2023, 08:41 |
nicola andreini
Rep Power: 6 |
I had the same error as you, in my case there was a variable in the code that had not been changed. Specifically in my code (SchnerrSauer cavitation model) there was an rRB(limitedAlpha) that I had forgotten to remove. Although the compilation returned no errors, once I launched the calculation I was getting the same error as you.
I hope it helps you. |
November 20, 2023, 16:34 |
#3 | |
Hamed Hoorijani
Rep Power: 7 |
c++ code, openfoam 5.x, turbule model |
