How to interpolate point data from a VTK file to the cell centers of a given mesh
Old   November 7, 2023, 08:42
Default How to interpolate point data from a VTK file to the cell centers of a given mesh
Aina
Aina is on a distinguished road
Dear Users,
We currently have an unstructured mesh and velocities in the form of VTK files for said-mesh. Our goal is to initialize a simulation using the velocity values in the VTK´s. The only problem is that the data given in our VTK files is in the form of point data.
Our question, is whether there is some executable in OpenFOAM that can interpolate this point data to the cell centers of our mesh (As we all know, OpenFOAM works with cell-centered values). Any help would be appreciated.
Regards
Aina is offline   Reply With Quote
Old   November 9, 2023, 02:57
María Rosales
MMRC is on a distinguished road
Hello Aina,
Is that VTK comming from another simulation done in openfoam?
if so, you have the the utility mapFields that will read the .C files of each field from the folder of solution (the time step you set) of your previous simulation . MapFields works even if mesh are different (example: in one you have an object that was not in the 1st mesh) and even for different B.C. It initializes the whole domain with previous data.
MMRC is offline   Reply With Quote
cell center, initialization, interpotation, unstructured mesh, vtk
[openSmoke] LaminarSMOKE compilation error mdhfiz OpenFOAM Community Contributions 8 July 2, 2024 11:32
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 12:04
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 18:18
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
