Write drag coefficient out from the drag model
Old   November 2, 2023, 01:44
Default Write drag coefficient out from the drag model
ZP zhao
ZX-zha is on a distinguished road
Hello, everyone!
I wrote a drag model, and i want to write the calculated coefficient to the file like the velocity or pressure file does.
So I wrote down:
    volScalarField KD
        IOobject
            "KD",
            mesh.time().timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::MUST_WRITE
        mesh,
        dimensionedScalar("zero",dimDensity*dimLength*dimVelocity/dimArea,0.0),
        relativeHeight_.boundaryField().types()
But it dsn't work, what should i do?
ZX-zha is offline   Reply With Quote
Old   November 3, 2023, 12:18
Saeed Jamshidi
saeed jamshidi is on a distinguished road
Hi ZX-zha,
I think you should give us more information about your procedures!!!
Make it more clear.
saeed jamshidi is offline   Reply With Quote
Old   November 5, 2023, 05:53
ZP zhao
Hello, saeed jamshidi:
More specifically, I want to export the drag coefficient to a file in each time step like the ordinary variables p or U.
But i don't know how to get the drag coefficient in the program. Can anyone help me?
Old   November 5, 2023, 06:12
Saeed Jamshidi
simply add the attached file into your system folder, and call it in controlDict/function as below:
functions
    #include "forceCoeffs"
care about format of forceCoeffs.txt
next, adapt contents of the forceCoeffs based on your problem.
this will create postprocess folder, which contains drag and lift data.
If you have any further question, please let me know.
Best,
Saeed
Old   November 6, 2023, 01:43
ZP zhao
Thank you very much for your advice. That helped a lot.
output
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 01:58
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
problem with saving drag coefficient colopolo FLUENT 5 April 12, 2013 11:59
Drag coefficient for parcels in dieselFoam sebastian_vogl OpenFOAM Running, Solving & CFD 5 December 31, 2008 13:19
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 09:43
