Strongly negative scalarSemiImplicitSource causing divergent behavior
Old   October 12, 2023, 13:32
Default Strongly negative scalarSemiImplicitSource causing divergent behavior
Martin Marone
MaroneM is on a distinguished road
Hello everyone!
I am trying to implement a personalized solver in openFoam in order to solve the transport of chemical species, and I am having some trouble to model a simple "cleaning" sink term on my equations. I based my model on what I would have done for an idealized heat-exchanger (since I am treating this chemical species as a volScalarField an therfore it is analog to the T field), so I am using a scalarSemiImplicitSource defined through the constant/fvOptions file as follows:
myElementSink
    type            scalarSemiImplicitSource;
    active          true;
     selectionModecell   Zone;
     cellZone                hx;
     volumeMode          specific;
     injectionRateSuSp
        myElement	(0 -0.4);
When I use values for the implicit term that are close to 0 (in the example it is -0.4) I obtain the expected behavior from the simulation. Nevertheless, if I go for strongly negative values (that I would need to model an efficient "cleaning" system) the simulation diverges and returns an increasing positive value (as if this was a source instead of a sink). If anyone has an idea of what might be happening and how to correct it, that would be great!
Just in case, the equation that I am solving with my solver looks like this:
        fvScalarMatrix myEq
              fvm::ddt(myElement)
            + fvm::div(phi, myElement)
            - fvm::laplacian(diffCoeff, myElement)
            + myExplicitSource
            + fvOptions(myElement)
        myEq.relax(RELAX_FACTOR);
        fvOptions.constrain(myEq);
        initResidual += myEq.solve().initialResidual();
        fvOptions.correct(myElement);
        myElement.correctBoundaryConditions();
Thank you in advance ^^
MaroneM is offline   Reply With Quote
Old   December 1, 2023, 10:47
Martin Marone
Ok, so I did not find a "detailed" solution for this but I ended up working with much higher relaxation (even bellow 0.4 in some cases) to get the simulations through.
divergence, fvoptions, scalarsemiimplicitsource, sink term, volscalarfield
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
