How to access boundary field values located on other processors?
Old   October 8, 2023, 09:11
Default How to access boundary field values located on other processors?
Sreehari Perumanath
sreehahaha is on a distinguished road
Dear Foamers,
Hope you're having a great day.
I'm solving a scalar transport equation which happens to have a fvc::div(traction) in the governing equation. The field traction here is a 'surfaceScalarField'. For trial purposes, I initialised traction = scalar(1.0) uniformly. However, I'm using cyclic boundaries, and so I changed the values of one boundary (say leftPatch) to be the negative of its cyclic neighbourPatch (i.e. rightPatch). Now when I evaluate fvc::div(traction) to add to the governing equation, which will be a volScalarField, it is uniformly 0 everywhere. This is expected and I'm happy.
However, when I run the same code in parallel, the output of fvc::div(traction) is not uniformly 0 everywhere as it should be. I think this is because a given processor is not able to access boundaryField data that is located on another processor.
Is there a way to solve this issue? Please let me know.
Cheers,
S
sreehahaha is offline   Reply With Quote
Old   October 10, 2023, 16:21
Klaus
klausb will become famous soon enough
"...I think this is because a given processor is not able to access boundaryField data that is located on another processor. ..."
You may have to write the code to process data across processes or to transfer data between processes. A good starting point to learn about it is the following programming tutorial:
https://github.com/UnnamedMoose/Basi.../OFtutorial5.C
klausb is offline   Reply With Quote
Old   October 11, 2023, 04:25
Sreehari Perumanath
Thank you Klausb. The link you sent will be definitely helpful.
Furthermore,
1. Could you please tell me how I can change the values of the "surfaceScalarField traction" at processor boundaries? Preferably using a loop. I saw some posts here suggesting to use pos(), neg() functions that avoid using a loop. However, in my case, I will have to give certain values to 'traction' at run time. I'm not sure if this can be done without using a for loop.
2. What does correctBoundaryConditions() do exactly? I read that it corrects the pressure values at processor boundaries when you give p.correctBoundaryConditions(). However, in my case, I only have a surfaceScalarField. So, I cannot do traction.correctBoundaryConditions(). I'm a bit confused how it works.
Thanks again,
S
Old   October 11, 2023, 07:03
Klaus
Dealing with processor boundaries is tricky.
Regarding 1: Read the following but you'll have to develop your own solution. Pout and Info are your friends to see what's going on at local and global level during develoment.
#4: Access patch points (on different processor) in parallel
http://www.wolfdynamics.com/training...g_openfoam.pdf
Flux at processor boundary
Neighbouring processor number for a patch
Access processor patches in parallel run
Old   October 12, 2023, 03:06
Sreehari Perumanath
Thank you so much Klausb, I will have a look at these.
Have a great day!
SP
boundary condition, field acces, parallel computaion
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 08:56
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
[Other] dynamicTopoFVMesh and pointDisplacement RandomUser OpenFOAM Meshing & Mesh Conversion 6 April 26, 2018 08:30
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
