Integrating over a specified plane during run
Old   September 25, 2023, 01:32
Default Integrating over a specified plane during run
Farzad Faraji
farzadmech is on a distinguished road
Hello all,
I want to calculate volume Flowrate and momentum over specified planes and report the value. My problem is that, I do not know how to define a plane. How can I define multiple planes inside the code? I wan integrate over cells and not over points, how it is possible?
Using below commands, I was just can integrate over points and not cells.
Calculate flux across surface
Thanks,
Farzad
farzadmech is offline   Reply With Quote
Old   September 25, 2023, 02:38
Farzad Faraji
ok, I find the answer;
when interpolate is false it is integrating over cells, and when interpolate is true, it is integrating over points. To execute the code we need;
postProcess -fields "(* * *)" -latestTime -dict system/integrateOnSurfaceDict
flux
        functionObjectLibs ("libfieldFunctionObjects.so");
        type            surfaceFieldValue; // volFieldValuerrrrrrrrr;  //surfaceFieldValue;
        enabled          true;
        writeControl     outputTime;
        writeInterval    1;
        writeFields      false;
        name farzad;
        // regionType: patch/faceZone/sampledSurface
        regionType    sampledSurface;  //cellZone;  //sampledSurface;
        sampledSurfaceDict
            type                  plane; //thresholdCellFaces; //plane;
            planeType             pointAndNormal;
            pointAndNormalDict
                point  (0 1 0);
                normal (0 1 0);
            interpolate false; //false;
        // Operation: areaAverage/sum/weightedAverage/...
        operation    areaIntegrate;  //areaNormalIntegrate;
        fields
        U.water
            U.waterMean
flux22
        enabled          true;
        writeInterval    1;
        writeFields      false;
        name farzad;
        sampledSurfaceDict
            type                 plane; // thresholdCellFaces; //plane;
            pointAndNormalDict
                point  (0 1 0);
                normal (0 1 0);
            interpolate true; //false;
        fields
            U.water
            U.waterMean
Originally Posted by farzadmech View Post
Hello all,
Thanks,
Farzad
Thanks,
Farzad
integrate, openfoam, plane
How Coorectly Run sampleDict FlyBob91 OpenFOAM Post-Processing 5 September 13, 2017 05:01
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 19:45
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 13:43
Mixing plane geometry definition Hbet FLUENT 0 January 18, 2002 08:16
