Interfoam UEqn.H, where to add additional terms?
Old   August 22, 2023, 09:04
Default Interfoam UEqn.H, where to add additional terms?
Luke Hirl
Luke99 is on a distinguished road
Disclaimer: probably already discussed somerwhere can´t find anything though, link would be enough
So I would like to add a electrostatic force term
- fvc::interpolate(rhoE)*fvc::snGrad(Ue) - scalar(0.5)* fvc::interpolate(EE)*fvc::snGrad(eps)
to the UEqn in interfoam and I looked at examples online. Some of them only seem to add it in the momentum predictor and others only in the fvVectorMatrix UEqn part or do i only need to add it in fvoptions or in both? Obviously not fvoptions and as a term in the same equation.
I know that if I add it to the momentum predictor only it needs to be turned on.
MRF.correctBoundaryVelocity(U);
    fvVectorMatrix UEqn
        fvm::ddt(rho, U) + fvm::div(rhoPhi, U)
      + MRF.DDt(rho, U)
      + turbulence->divDevRhoReff(rho, U)
      to add here?
        fvOptions(rho, U)
    UEqn.relax();
    volScalarField EE = magSqr(fvc::grad(Ue));
    fvOptions.constrain(UEqn);
    if (pimple.momentumPredictor())
        solve
            UEqn
            fvc::reconstruct
                    mixture.surfaceTensionForce()
                  - ghf*fvc::snGrad(rho)
                  - fvc::snGrad(p_rgh)
                   or here?
                ) * mesh.magSf()
        fvOptions.correct(U);
Luke99 is offline   Reply With Quote
Old   August 23, 2023, 10:18
yijin Mao
alundilong is on a distinguished road
    fvVectorMatrix UEqn
      + MRF.DDt(rho, U)
      to add here?
        fvOptions(rho, U)
    UEqn.relax();
        solve
            UEqn
            fvc::reconstruct
                   or here?
                ) * mesh.magSf()
Luke99,
do you think pEqn should be changed accordingly?
if you've known how U and pEqn come, you will see what and where changes should be imposed.
alundilong is offline   Reply With Quote
Old   August 28, 2023, 17:34
Luke Hirl
Hi Alundilong,
so I read a bit further into the solver.
Correct me if I am wrong but as far as I understand it the Navier-Stokes Equation is solved as follows:
In the UEqn.H I first construct the U vector Matrix and then have the option to use the momentum predictor to kind off precalculate the velocity field. But the final calculation of the velocity field happens in pEqn.H after I iteratively solved the pressure Equation.
So therefore as you already said I should either implement it in the U vector Matrix or the pressure Equation and in the latter case if I want to use the momentum predictor there as well.
Old   August 29, 2023, 04:26
Domenico Lahaye
dlahaye is on a distinguished road
You can use source function object to specify a momentum source term.
See e.g. https://www.openfoam.com/documentati...s-sources.html .
dlahaye is offline   Reply With Quote
electrohydrodynamic, interfoam, modify solver, term, ueqn.h
how to add additional species diffusion term in FLUENT Sowmiya FLUENT 3 March 28, 2021 14:34
Modeling Additional source terms Abed Main CFD Forum 0 November 24, 2007 07:17
how to add source terms to a cell? lily FLUENT 5 May 24, 2006 05:38
Source terms for additional variable transport eqn Nandini Rohilla CFX 0 February 6, 2004 14:38
Additional terms in Differential Stress Model Fabio Kasper CFX 1 February 9, 2000 03:39
