Heat pipe Simulation
Old   July 30, 2023, 10:23
Arrow Heat pipe Simulation
Jaymeen Patel
jaymeen721 is on a distinguished road
Hi, I am working on Heat pipe numerical simulation and, wish to simulate heat pipe for multi phase flow physics including boiling and condensation. I found one solver interCondensatingEvaporatingFoam, but it is not nucleating boiling or condensation, it only gives phase change.
On the other hand I have modified interFoam of OF-9 version as per Paper 'The evaluation of the diffuse interface method for phase change simulations using OpenFOAM' The solver is working fine for Stefan's problem and 2-D film boiling but it not works for horizontal film and other condensation problem. During condensation the min. alpha value goes below zero and then time steps starts running in 10^-15 range. Can anyone help me in this problem.
Thanks in advance
jaymeen721 is offline   Reply With Quote
Old   August 25, 2023, 10:09
Khaled Yassin
Yassin-K is on a distinguished road
I am not an expert in the field you are asking about, but have you tried to add a constraint in the system/fvConstraints file to set min. alpha = 0?
Best Regards,
Khaled Yassin,
Research Assistant
Institute for Energy and Environmental Research (IEK-14)
Forschungszentrum Jülich
Yassin-K is offline   Reply With Quote
Old   August 26, 2023, 05:39
Jaymeen Patel
Thanks, I will look for that
boiling, condensation, heatpipe
Multiphase simulation heat pipe Sai245 CFX 2 May 19, 2020 16:46
Heat pipe simulation bensonnggl CFX 17 September 3, 2017 21:42
Heat pipe simulation in CFX abymathew CFX 1 November 3, 2015 18:31
simulation of heat pipe (evaporation part) DanielLai FLUENT 0 November 5, 2011 11:26
FEA Simulation of heat pipe bensonnggl ANSYS 0 September 25, 2010 01:59
