Access refValue of Boundary condition
Old   July 25, 2023, 11:39
Default Access refValue of Boundary condition
Peter Vorauer
Rudiy is on a distinguished road
Hallo, i am working at a chtMultiRegionSimpleFoam Solver to calculate the jouleHeating at a boundary with contact resistance.
For the calculations i would need to access the refValue of a certain boundary in the boundaryField.
I managed to get the average Value at the boundary field with:
const fvMesh &PoP1 = V_.db().parent().objectRegistry::lookupObject<fvMe sh>(region1);
const volScalarField &solidT1 = PoP1.thisDb().objectRegistry::lookupObject<volScal arField>(field);
double Pot1 = gAverage(solidT1.boundaryField()[patchID]);
but i would need the refValue of
does someone know how to do this?
Rudiy is offline   Reply With Quote
Old   July 25, 2023, 14:54
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
I would typically code something like this:
const auto& mesh = V_.db().time().lookupObject<fvMesh>(region1);
auto* solidT1 = mesh.getObjectPtr<volScalarField>(field);
double Pot1 = 0;
if (solidT1)
    auto& bfld = solidT1->boundaryFieldRef()[patchID]);
    Pot1 = gAverage(bfld);
    bfld = Zero;  // Or whatever ...
The getObjectPtr method is very convenient since it combines a test-if-exists and a const_cast.
If you stick with most of your own code, you will need to do a const_cast on the volScalarField in order to use the boundaryFieldRef() access.
olesen is offline   Reply With Quote
Old   July 26, 2023, 03:31
Peter Vorauer
Thank you very much for your reply. I would have an other question.
If i use your code i get for the bfld variable with:
Info << bfld << " = bfld" << endl;
the following result:
type compressible::PotentialRadCoupledMixed;
refValue uniform 0.571153;
refGradient uniform 0;
valueFraction uniform 0.0161289;
source uniform 0;
value uniform 0.923078;
Tnbr myjouleHeatingSource:V;
sigmaLayer constant 66666;
sigma constant 200000;
kappaMethod solidThermo;
= bfld
now i would need the values of
refValue uniform 0.571153; and
is there a way to get these values ? (instead of using gAverage(bfld))
Old   July 27, 2023, 13:55
Mark Olesen
You will definitely need to read some documents there. The general boundary field is generally derived from a Field of Type, so that part is fairly straight forward to get at. The other bits such as "refValue uniform ..." and "sigmaLayer constant ..." are either still available as plain dictionary entries that you can scrape back together (if you have a coded access to a dictionary, for example), or if you know what the underlying boundary type actually is, you can dynamic_cast (or refCast for OpenFOAM) into the corresponding type. However, I don't know offhand if these elements are directly exposed as methods for any particular subclass. In either case, they are a PatchFunction1 or Function1, which means you will need to evaluate them with a given time value.
Fatal overflow in linear solver. iamnotfajar CFX 9 October 28, 2020 05:47
Constant mass flow rate boundary condition sahm OpenFOAM 0 June 20, 2018 23:45
How access member variable of a boundary condition Vesposo OpenFOAM Programming & Development 1 March 13, 2014 08:49
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
