FOAM Warning : Field " " not found in database for averaging |
July 22, 2023, 15:13 |
Khaled
Rep Power: 3 |
i have created source code to define fields/terms, then compiling these src and using the lib.so later in the post-processing by using `rhoPimpleFoam`. I am using OpenFOAM 1612+ The problem that when i am trying to write these fields in the `field` for averaging function in the `controlDict` , it is returning me always this warning Code:
--> FOAM Warning : From function void Foam::functionObjects::fieldAverage::initialize() in file fieldAverage/fieldAverage.C at line 95 Field UU not found in database for averaging Code:
Starting time loop fieldAverage fieldAverage1: Restarting averaging for fields: U: starting averaging at time 0 p: starting averaging at time 0 T: starting averaging at time 0 rho: starting averaging at time 0 UU: starting averaging at time 0 Code:
functions { .... fieldAverage1 { type fieldAverage; libs ("libfieldFunctionObjects.so" "libMTSFunctionObjects.so"); writeControl writeTime; fields ( ... UU { mean on; prime2Mean on; base time; } ); } } I have tried everything, i have used `write()` function to write it in the desk as `UU.write();` . The compiling proceed with no errors or warnings. Update: when i have tried to call `UU' in the function before `fieldAverage`, it is calculating UU normally with no problems, but still the same warning when averaging: Code:
Current time: 0.02 calc() function called UU calc starting Calculated UU tensor: dimensions [1 -1 -2 0 0 0 0]; internalField nonuniform List<tensor> 742716 Best regards, Khaled Last edited by elbatawy; July 24, 2023 at 10:56. Reason: improving the writing way |
July 24, 2023, 14:41 |
Mark Olesen
Rep Power: 40 |
Check that your "UU" field is registered and also that it is still in scope (ie, you haven't accidentally destroyed it).
controldict, openfaom, rhopimplefoam |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 14:21 |
[mesh manipulation] RefineMesh Error and Foam warning | jiahui_93 | OpenFOAM Meshing & Mesh Conversion | 4 | March 3, 2018 12:32 |
[Other] Mesh Importing Problem | cuteapathy | ANSYS Meshing & Geometry | 2 | June 24, 2017 06:29 |
8x icoFoam speed up with Cufflink CUDA solver library | kmooney | OpenFOAM Running, Solving & CFD | 42 | November 6, 2012 12:37 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 05:41 |
