June 15, 2023, 12:54 |
Time consumer of simulation time
Naomi Mestre
I am running a sediment simulation using sedFOAM from the OpenFOAM software. I did a 10s simulation and it took me approximately 24h. Then, keeping everything the same except for the application of an equation in the inlet of the Boudary condition, I performed a simulation of 0.6s and it took me about 24h.
Could someone tell me if it is really normal that applying an equation in the inlet of the boundary condition increases the simulation time so much? If it is not normal, could someone provide me with some tool to make the simulation more efficient? Thank you very much in advance! |
June 16, 2023, 04:20 |
Rep Power: 14 |
Okay - let's break this down a little. The main question you are raising is "why is the simulation taking so much longer"?
I don't know sedFoam, but in any typical low Mach# flow solver there are three parts to each time step - calculations of initial velocity estimate; pressure calculation and velocity correction; calculation of turbulence and other transport equations. The first and last are generally very quick - from a numerical perspective they are typically trivial. The pressure solution is almost always the most expensive part of the simulation. So - take a look at your log file and look at how many linear solver iterations are being done on the pressure field for each solver iteration (i.e. time step) - has this gone up significantly? Is it hitting the maxIter bounds? If so, then this will be why it is taking so much longer. Assuming that this is the case, then the next question is of course "why is it doing that?" Simply put, you are asking the solver to do too much work on each time step - the pressure field and velocity fields are probably changing too much, and indeed you may not have got a sensible pressure solution by the time your solver hits the maxIter limit on the linear solver iterations. Try reducing your time step ... I hope the above gets you thinking in the right direction. Good luck! |
boundary condition, inlet, time consumer |
bash script for pseudo-parallel usage of reconstructPar | kwardle | OpenFOAM Post-Processing | 42 | May 8, 2024 00:17 |
courant number increases to rather large values | 6863523 | OpenFOAM Running, Solving & CFD | 22 | July 6, 2023 00:48 |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 03:36 |
pressure in incompressible solvers e.g. simpleFoam | chrizzl | OpenFOAM Running, Solving & CFD | 13 | March 28, 2017 06:49 |
plot over time | fferroni | OpenFOAM Post-Processing | 7 | June 8, 2012 08:56 |
