Dimension error -It don't match the expected dimensions
Old   May 31, 2023, 02:02
Smile Dimension error -It don't match the expected dimensions
Hana Suda
Hananas is on a distinguished road
Hi everyone,
I am Hananas and new to OpenFOAM.
I am arranging buoyantBoussinesqSimpleFoam so that it can calculate absolute humidity. The name of this new case is "X_buoyantBoussinesqSimpleFoam".
However, core dump occurred after I run the code.
So I checked the log file, and it said "The dimensions [0 2 -1 0 0 0 0] provided do not match the expected dimensions [0 0 0 0 0 0 0]"
My question is;
How can I change the expected dimensions [0 0 0 0 0 0 0] to [0 2 -1 0 0 0 0]?
The dimensions of DX should be [0 2 -1 0 0 0 0]. So, I need to revise this expected dimensions. I guess it came from the dimensions of X(I set the dimensions of X as [0 0 0 0 0 0 0] because it is [kg/kg(DA)])
I am looking forward to your reply!
I attached the files and will write where I revised after this comment. So please confirm them.
Hananas is offline   Reply With Quote
Old   May 31, 2023, 02:05
Default Where I revised
Hana Suda
[X_buoyantBoussinesqSimpleFoam]
1. file name: X_buoyantBoussinesqSimpleFoam.C
I added #include "XEqn.H" in the 94th line.
2. file name: XEqn.H
I created this file (I refered to TEqn.H).
3. file name: readTransportProperties.H
I added "Vapor diffusion number" and "Turbulent Schmidt number" in the 20-24th line.
4. file name: createFields.H
I added some code to calculate X in the 17-29th line.
[hotRoom]
1. file name: 0/X.orig
I created this file (I refered to T.orig).
And I added \cp 0/X.orig 0/X in the 8th line in Allrun.
2. file name: constant/transportProperties
I added "Vapor diffusion number" and "Turbulent Schmidt number" in the 35-39th line.
3. file name: controlDict
I revised the name in the 18th line.
4. file name: fvSchemes
I added a code related to X in the 34th line.
5. file name: fvSolution
I added X in the 28th & 48th & 65th line.
absolute humidity, dimensional error, openfoam, solver development
ParaView: Number of cells/points in mesh and field don't match Jaggy_Snake OpenFOAM Bugs 2 March 1, 2017 10:06
FSI: Pressure and Normal Force don't match with expected values Geraud CFX 6 August 21, 2012 16:34
Match Control and Symmetry Boundary Condtions in a quasi 2D calculation peterputer ANSYS Meshing & Geometry 0 May 15, 2012 09:53
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 07:42
gmsh2ToFoam sarajags_89 OpenFOAM 0 November 24, 2009 23:50
