6dof solver(sixDoFRigidBodyMotion) for multi-body(dynamicOversetFvMesh) |
Yateng Qiao
Rep Power: 3 ![]() |
Dear all,
I'm recently trying to deal with two ellipsoid bodys in pure shear flow. The single ellipsoid body is simulated successfully, but when dealing with multi body there are some problems. The method I used is dynamicMesh:dynamicOversetFvMesh; application ![]() solid body motion solver:sixDoFRigidBodyMotion; According to Multiple Floating Objects with 6DoF in OF 2.3.0 I add following codes in dynamicMeshDict: solvers { ellipsoid1 { ... } ellipsoid2 { ... } } There exists two main problems: 1. the pointdisplacement file in the post-processing can only display the ellipsoid1's mesh motion, mesh motion is not included in Pointdisplacement file in time folder. The result I post out here. 2.the Courant number becomes very large from the second time step, which means the simulation is not converged As Bruno in the Previous link said:"A possible solution for this would be to create a new class that is based on "sixDoFRigidBodyMotionSolver" and that can then handle more than one body." I guess the problem is the solver itself, So I want to ask if it is possible to creat two dynamicMeshDict for two bodys, then I Initialize two objects from mesh class. The two objects reads the solver coffes in two dynamicMeshDict files. First I update the first object's motion , then I used the updated mesh to update another object's motion like this in overPimpleDyMFoam: ... ++runTime; Info<< "Time = " << runTime.timeName() << nl << endl; mesh1.update(); mesh2.update(); if (mesh.changing()) ... I'm not sure if it is possible to do that, if can if there is anything aviliable to use as a reference. ![]() ![]() ![]() Kind Regards, Q. |
Yateng Qiao
problem is done, it's not the solver's fault. I made a mistake.
dynamicmesh, multibody patch, overset, sixdofrigidbodymotion |
why fluent 6dof rotational mass cannot be changed?? | EngGhost | FLUENT | 7 | January 31, 2023 23:40 |
unable to run dynamic mesh(6dof) and wave UDF | shedo | Fluent UDF and Scheme Programming | 0 | July 1, 2022 17:22 |
6DOF formulation help in OF - body or inertial reference frame? | quarkz | OpenFOAM Programming & Development | 4 | June 5, 2022 21:33 |
Modelling Contact and Frictional Force in 6DOF | wcj1n18 | Fluent UDF and Scheme Programming | 2 | March 12, 2021 04:17 |
Buoyancy and the 6DOF solver (FLUENT) | i2a | FLUENT | 16 | March 20, 2020 11:20 |
